Highly modified. 1.6L Kent engine, .060” over, forged pistons, Carillo rods 1.25 racing cam, big-valve aluminum head, 4 core radiator 95 amp GM alternator 4-into-2-into-1 2” exhaust, JetHot coated Aluminum valve cover Electric fuel pump Mocal 13 row oil cooler w/ thermostat High volume oil pump Crank-trigger coil-less ignition Heavy duty clutch Quaif limited-slip differential Lowered 35mm, stiffer springs Anti-dive kit 19mm rear anti-roll bar Wilwood 4-pot front calipers, XR2 rear disc conversion Stainless steel brake lines Braided Stainless brake lines 14” 6 spoke Oz alloy wheels, Bridgestone tires Euro headlights, turn signals, grill Ford part body kit, skirts, wheel extentions Ford part rear spoiler Factory sun roof Rear wiper/washer Heated rear screen Ghia interior, package shelf Koenig racing seats Stroth 4-point harnesses Autopower rollover bar K&N air filters Center console with VDO gages: clock; oil temp; oil pressure; amps; volts; vacuum 140 mph speedometer; tach; gas; temp; Hella horns Dual side mirrors. Spanks rice burners!!
