I bought this 1971 Corolla TE27 10 years ago for $50. My girlfriend learned to drive it for her first license then later I married her. This car will eventually be powered by a 2005 L33 Vortec Small-block and 2005 C1500 5-speed manual transmission.
The front radiator mount/support is complete. I used the stock dodge rubber mounts.
Here you can see the rack and pinion mounted, the right hand motor mount and …
I returned the Infinity radiator to pick n pull and they allowed me to return …
I have the suspension mocked up with the bimmer rack. I bought some QA1 rod …
I bought a ‘89 BMW 325i rack-n-pinion today. It is also power assist, so, if …
The Infinity radiator I got today comes really close to the throttlebody. It looks as …
With bailing wire and remnants of the stock crossmember I flipped the corolla suspension backwards …
The tunnel for the transmission is almost done I had to take a break from …
The transmission is done and the floor was clearanced so that 2.25” dual exhuasts can …
The clutch and brake master cylinder had to move over 4” to the left and …
I fabricated motor mounts from 3/16”x2” cold rolled tubing and the stock corolla mounts.
Two flexalight pusher fans will blow through a corvette radiator. I had to switch to …
I have the motor and transmission inside the car for fitment. And it fits good. …
