A 1970 Datsun 240z 3.0 liter, tripple Weber Carbs, Ground Control Coil-overs, Tokico springs, Illumina struts, Design Products camber plates, carbon fiber wheel flares, Compomotive 15x8 front and 15x9 rear wheels, Hoosier cantilever tires, Griffen alum radiator, Crane optical ignition, shaved Rebello Racing cylinder head; ported, polished, shaved. Rebello Racing AX cam, Nissan Comp variable cam gear, Nissan Comp lsd 4:11 differential, Design Products solid differential mount, 1981 s130 5spd, HKS 9lb flywheel, 3 puck clutch, short throw shifter. Wilwood 6 pot brake calipers, 12’ Wilwood vented rotors, steal braided lines, Motul brake fluid. 2.5” exhaust, Dynomax muffler…..More to come.
You'll need to log in to post. Log in
