Started on Oct. 10 by spydrb8
1973 Volkswagen Super Beetle
His name is Mojo, or Spyder Bait because he likes to tease faster cars. Chassis: 4 wheel disc brakes coilover front struts 22mm front sway bar, 17mm rear formula vee sway bar kamei front air dam Porsche 17x7 cup 3 wheels, 215/40 17 Dunlop Direzza Star Spec Engine & Transmission 2176cc CB aluminum case DPR 78.4mm crank Mahle 94mm forged pistons and cylinders CB 5.5” race rods CB #2246 cam, 260 dur. @ .050” .411 lift CB straight cut cam gears CB lightweight lifters Scat chromoly push rods Windage tray Scat wedge port heads, 40mmx35.5mm CB 1.3:1 forged rockers, measured out to 1.25:1 and .515” lift at the valve 30mm HD oil pump w/ filter 12 lb. lightened flywheel KEP stage 1 pressure plate Rancho Pro street Freeway Flier Single side cover case, w/ HD cover 3.78, 2.06, 1.26, .89, 3.88 R&P welded 3rd, 4th hubs steel synchos and shift forks
Add your comment
See more
wfcMoV2aGAVQBM9AhC0zeMjWoYW3AwncrNUr3mGHsXOn7I8QxVDv0m6uj81ZNRAC
