Owned it for 2 years. JY motor & gauge cluster (factory tach) out of a ‘96 Paseo, 258k on the motor. Custom hybrid trans using AE101 gear set with TRD 2-way LSD. Custom modified exhaust manifold, 2.25” 409ss mandrel-bent exhaust from the manifold back, with a metallic high-flow cat, 22” long Magnaflow resonator & I have 3 different rear sections for it, i typically have an AeroTurbine out back. Ksport adjustable upper mounts, KYB GR-s dampers, Vogtland springs (trimmed one soft coil up front) WhitleLine Caster kit up front, WhiteLine adjustable rear Panhard bar, Ultra Racing 20mm rear sway bar, EP82 Starlet front strut brace. 1st gen Paseo front brake calipers & rotors with Hawk Pads, ATE Super blue brake fluid, TechnaFit braided lines. 15x7 Kosei T1-S wheels with 205/50-15 Sumitomo HTR Z rubber. Speed Hut Oil pressure gauge, & ScanGauge II.
