81 4DOOR. STOCK 4 CYL/5 SPEED WAS DITCHED IN FAVOR OF SBC 350/350 TRANS. HAVEN’T BROKEN THE STOCK AXLE…YET! VERY UNASSUMING! AN ALL ALUMINUM 5.3ltr IS WAITING IN THE WINGS FOR WHEN THIS GETS BOREING!!
The passenger side header is almost completed. Just some finish welding and off to the …
The headers are coming along nicely. It is definately a labor of love and very …
I have been slowly roughing in the tubes with mild steel. They are looking pretty …
The rear shock towers were a little rotted out in the back of my car …
We found and junk engine core with a spun rod. My friend has extra parts …
Got started last weekend and found out that this work is not too bad. I …
Slight modifications were necessary to get the 1 7/8” tube into the flange. I have …
Well, ran into my first challenge. I found out that the pipes won’t fit in …
My friend and I are going to change a few things this year. So, new …
Straight door bars just are not gonna work with how small the door openings are. …
I needed some gussets to go in the corners for support. I found some nifty …
I bought a cheap muffler to make it quieter. I welded a small pipe to …
I need another small arm to help actuate the dump lever. I used an old …
Now that i have the dump constructed,i need something to control it. I drew out …
The sprint car muffler help quiet the exhaust down some,but it is not enough. I …
No one makes anything for a sbc and corolla swap. Everything has to be made …
After the side brackets were built,i fiberglassed them in so air would be trapped and …
HAD TO MOVE THE MASTER CYLINDER TO MAKE ROOM FOR THE NEW MOTOR AND TO …
