1988 BMW E30 M3 Bored and stroked S38B36 - 94.5mm, 10.75:1 Custom Pistons, Euro 3.8 Crankster, Euro 3.8 Rods, SuperTech 39mm Intake vales / 33mm Exhaust Valves with 5 Angle Valve Job, Viton valve seals, Stock 264 intake/exhaust cams with adjustable cam sprockets set to 108cl intake and 112cl exhaust, 31mm intake ports. Euro 3.8 50mm throttle bodies, euro M88 exhaust manifolds, Vi-Pec V88 EMS, Injector Dynamic 725cc injectors, Sequential injection/ignition, Ground Controls “e36 on e30” Coilovers, 525# Front & 750# Rear. AKG 80A Diff, 75D RTAB w/ camber & toe adjustable MZ3 Trailing arms, custom engine Mounts, AKG 80A Rear Subframe Mounts. MZ3 Finned Rear Diff cover. Every suspension and engine bolt brand new, powdercoated rear subframe, trailing arms, front subframe. Stock E36 M3 Front brakes with euro floating rotors, ss brake lines, custom driveshaft, Getrag 265 trans with Sachs E34 M5 6 Spring sport clutch, AutoSolutions SSK, 3.91 LSD.
