Picked this up for a $2011 Challenge build. Plan to install cheaply purchased running motor, suspension, 914 wheels. Won’t be much to look at with all the rust but it should go and stop reliably. B
Moved the battery to the trunk. Well, I got the base built. Will make a …
Found some tastiness on the bottom of the block when I finished pressure washing the …
Thankfully, brakes are free in the Challenge budget because I’ve had to replace just about …
Plans are starting to come together. RatGhia will be supplying many of the parts we …
I may have found a parts car and all the new sheet metal to put …
