Started on Jan. 2 by flashmatrix
1986 Honda CRX Si
A lil project I took on the past 2 years. This car started out as a basketcase and has been redone to be a nice little driver. Specs: Factory EW 1.5 12 valve with some massaging… -Hedman/Chikara header -DIY Intake with K&N filter -Mild Ported & Polished TB/IM & Head -Gude/Bullfrog street camshaft -AEM adjustable cam gear -NGK Plugs and wires -MSD Blaster 2 coil -Spec pressure plate (clutch) -ACT street disc (clutch) -Motul fluids through out -KYB GR2s all around -Resplined torsion bars -Monkey Tek coilovers #350 springs -Energy Suspension bushings -GAB Sports front strut bar -AEM/Nissin brake pads -Powerstop drilled brake rotors -14x6 Kosei Grand Infest D5 -OMP Corsica wheel and shiftknob -Carbon pieces and overlays throughout -Stewart Wrner LED shift lite with digi tach -Voltmeter and Vaccum gauges -Walmart spec Pioneer radio -Kicker 6 1/2 speakers -1pc Heeltoe Auto Carbon ZC hood -5g accord front lip cut to fit -99 civic coupe sideskirts cut to fit -OEM Honda mudflaps -OMP hood pins -4300K HIDs -EDM CRX corner lights -JDM CR-X 1.5i badge
Add your comment
See more
CY5jkJzQ36QISaILcRIdaXqHxooO5zcBYczAD9vkT40jzQBxRRXCVWitUxGVwwsE
