Non-donor build. Roush/Alcon 14” front brakes, IRS, Koni coil overs, fuel cell. Should be receiving 18” Forgeline GZ3R wheels, 10” front & 11” rear, in a week. I installed a stock, for now, 5.0L Ford. I started to accumulate the Trickflow package to turn it into a Challenge Spec motor (my next build??). I also installed a used TKO-600, but I need to pull it to trim the Lakewood bellhousing for frame clearance, and to fabricate hydraulic slave cylinder bracket. (Just got the steel and welder)
instrument panel is wired..painted in truck bed liner. Non-structural cross member on trans tunnel cut …
Finally recovering from a divorce & surgery…did some work over the last few months… floors, …
