Started on Aug. 10 by Dren
Honda Civic Dx hatchback
The plan is for this to be my daily driveable track car. I’m building this car to do everything I want with as little compromise in performance as possible. (Yeah I know, good luck right?) I want to be able to drive the car on the street whenever I feel the urge as well as participate in HPDEs and run it at Maxton (and some other events too, I’m sure). I’ve make modifications to most areas of the car. It currently has Ksport coilovers, Civic Ex front sway bar, Tanabe rear sway bar, urethane control arm bushings (with Zerk fittings so I can grease them), Fidanza aluminum flywheel, etc, etc. Check out the more pictures link for a full list of everything I’ve done so far. I just received some of the last parts I needed to finishing a custom turbo install. After that I’ll tackle the interior safety equipment. I still have a ton of work to go and will probably never be done, but I’m loving every minute.
Add your comment
See more
1ySLXwjbGBxil9t9xjn26WP5XTMOfvGlhtGkwOs2cU6MjagHlEOhN099NKv445cO
