Started on May 6 by mhoward1
2006 Factory Five Challenge
Our FFR Challenge car. We aquired it last year and have added our livery to it. So far the car has been great. Some general specs on it: Frame Tubular space frame with Sub-structure Aluminum chassis panel, bonded and riveted to frame. Engine Boundurant Built 302 Drivetrain Transmission Borg Warner T5WC 5 Speed Rear Differential Gear 2:73 : 1 Clutch Stock Mustang 10.5” Suspension Front Suspension Independent un-equal length Upper and lower a-arms Rear Suspension Solid live axle, 4-link** Shocks-Springs 4 corner aluminum coil-over Steering Manual rack and pinion Brakes 11” front discs and 10.5” rear disc brakes. Tires Toyo RA1 255/45/17 Dimensions and Weights Minimum Weight 2450 lbs. (incl. Driver) Weight Distribution 46/54% (front/rear) Wheelbase 90 in. Overall Length 13’6” Track (front/rear) 56.0/58.5 in. Overall Height 46.5 in. Overall Width 72 in. Ground Clearance 4.0 in. Performance: Acceleration 0-60 mph 4.80 sec 0-100 mph 13.9 sec 0-120 mph 27.9 sec Standing ¼ mi. 13.6 sec @ 99 mph* Roadholding (lat G) 1.12 g* Best ¼ Mile 12.85 sec by a similar car Top Speed (est.) 145 mph
Add your comment
See more
84aB0YEBACjS9zodB0LQuovx9PLW5Cf0NoVqOf7MLelzU1wBk9F3A3qn7bmnzrbK
