Cobb Stage 2, Cobb Down Pipe, SPT Cat Back Exhaust, Tokico D-Specs, Swift Springs, Group N Strut Mounts, Cobb Front and Rear Sway Bars, TIC Rear Trailing Arm Bushings, TIC Lateral Link Bushings, White Line Front Control Arm Bushings, MSI Direct Steer Kit, White Line Steering Rack Bushings, Rear Subframe Lock Bolts, STI Front Brembo Upgrade, H6 Rear Upgrade, Hawk HP Plus Brake Pads, Goodridge Brake Lines, Super Blue Brake Fluid, Enkei RPF1 (Black), Dunlop Star Specs, Braille 17lbs Battery, Custom front brake duct set up with using Corvette Z06 Ducts.
I’ve been autocrossing and using this car for track days for 5 years now. I’ve …
Used the brakes at an autocross for the first times last weekend. I can drive …
