Started on Aug. 5 by ToddTCE
2000 Yamaha Wells Coyote
The company money pit! Seeing as there is no listing for “other” or “Open Wheel” we’ll just call it a Yamaha based on it’s SHO power plant! Chassis: All aluminum, tube frame. Modular design for break away safety. Much of the frame and mounts to it are held in place via saddle mounts and hose clamps. Originally produced by veteran Pikes Peak builder John Wells, the frame has been highly modified by both TCE and Stewart Fabricating in Phoenix. Suspension: All aluminum. Double A-arm front, multi link rear. Custom upper and lower A-arms by TCE, F-K aluminum rod ends, swaged aluminum straight links. Aluminum front spindles with Wilwood wide five hub assemblies. QA-1 coil over shocks with various spring rates. TCE built rear uprights featuring VW Type II hubs with wide five wheel adapters. Brakes: Wilwood of course. NDL front calipers, BDL rear calipers on custom TCE rotors and hats. Dual master cylinders. Turning brake. Polymatrix D compound pads. Engine: 3.5L SHO, 24v, stroked V6. 13:1+ CR. Estimated at 400hp. N/A, custom heads, intake, Stage II cams, custom Marren Injectors, Morrell/Dix tuning, underdrive water pump, mini alternator, lightened pulleys, JE pistons, Total Seal, K&N with outer wear. Custom oil injection and cooling systems. Kennedy light weight flywheel. Transaxle: TCE built Mendeola/Hewland custom. Four speed, straight cut, dog box. Hewland Mk5 gears, Formula Mazda rear carrier and shifter housing. Engine adapter by Kennedy, special built Stage III clutch kit with aluminum pressure plate. VW Type II CVs on custom 300m shafts. Wheels/Tires: 15 x 5 front wheels by Bogart, 15 x 12 rear by Circle. Both ‘wide five’ pattern, all aluminum. Goodyear Formula Vee rain tires up front with Goodyear Pikes Peak Specials on the rear. *Sprint car tires for Mt. Washington. Wings: Max allowable; 16sq foot front and rear. Modified FM race car wings to wider design. Fluids: VP racing fuel, Royal Purple Motor oil, Redline Shock Proof Gear Oil, Wilwood 570 Brake Fluid. General: Weight: 1470 w/driver. Wheel base: 92”. Fuel cap: 4g. Track; 55” front/70” rear.
Add your comment
See more
PBMQosLF1ClJtQHsMN4LBabUxdhxR3cwnhXd2FN061pzRoJj4xWL3AM8rpgYIBaW
