1988 Saab SPG modified for land speed racing. Raced from Fall of 2008 to May 2021 in East Coast Timing Association at Maxton NC, Willington OH, Blytheville AR and Loring Timing Association at Loring ME. Best speed in the mile 170.454 mph 30 psi boost at Wilmington in May 2015.. Best speed in the 2 Km. 173.044 km 30 psi boost at Blytheville in May 2021. Modifications 2.0L short block 2.1L cylinder head & 2.1L Intake Wiseco custom forged pistons - 9.0 to 1 c.r. SAAB/Crower regrind camshafts 267 degree duration; .348 lift; 8,000 rpm valve spring set Master Power 70 series turbocharger with external wastegate 2-stage adj. boost control Deatsch Werks 78 lb-hr fuel injectors Deatsch Werks DW301 high volume fuel pump Custom 3” I/O intercooler & plumbing with 5L Ford throttle body Custom modified carbon Kevlar clutch disc Autobahn #8 primary drive gear set Quailfe ATB limited differential Solid motor mounts KD custom tube header with T4 merge collector 3-inch street exhaust with Flowmaster muffle; Race 3-inch straight pipe Cooling Mist water injection Megasquirt MS3 Fuel Mgmt. sys. AFCO 400 lb. rate front springs with adjustable ride height jack bolt KD custom 8-point roll bar & door bars RJS 4-point race belts Firefox 5 lb. aqueous fire suppressant system Custom front air dam Dyno April 2015 - 391 whp 25 lbs. boost at 6,000 rpm; torque 349 lb-ft at 5,850 rpm
88 Saab SPG Land Speed Racer running at East Coast Timing Association Ohio Mile events …
