1990 Miata, Bought it for $1500, covered in truck bed liner, but mostly stock. Working on setting it up for SCCA CSP Currently it has 123,000 miles on it Here is the list of modifications Currently Installed: Hard Top (and soft top delete), Hard Dog Hard Core Hard Top Single Diagonal, Panasonic CD Player, DDM Works Gauge pod (holds 2 standard sized autometers in the spot below the radio), Odyssey PC680 in Aluminum Tray, Porterfield RS4 Brake Pads & Brembo Blanks, RX-7 MAF and Cone Filter, Fans wired in paralell and manual switch added (through relay). Street wheels and tires - TRMotorsport C1’s in 15x7.5 with Kumho Ecsta XS in 205/50/15’s AutoX Wheels and Tires - Diamond Racing 13x9’s with Hoosier 255/40/13 A6’s Future Mods include: Flyin’ Miata Rear Strut Top Hats (have) Flyin’ Miata Springs (need) H&R 25mm Front Sway (need) Tokico Illumina Struts (need) 1996 Rebuilt 1.8L Motor(have) Racing Beat Header (need) Cold air intake with MAF Delete (need) MS PNP (need) FM 1.8L Swap Kit (need) FM 10.3lb Flywheel and Clutch Kit (need) Torsen Swap (have)
She will be painted soon (back the original red) so here is a picture of …
