Engine: - 6.2L LS3 V8 - EPS 236 242 .600 lift camshaft - LS7 Roller Lifters - Comp Hardened Pushrods - Comp Dual .650 Lift Valve Springs - Hardened Seats - Titanium Retainers - All New GM seals and Gaskets - New LS6 oil pump - Billet double roller LS2 timing chain - 160 degree Thermostat - Nick Williams 92mm Throttle Body - 2010 Corvette intake manifold - 42 lb Injectors - Dedicated Motorsports 1 3/4 Headers with 3 inch collectors - Dedicated Motorsports Mount kit - Dedicated Motorsports Modified Ls2 Oil Pan - DM Power Steering Line Kit - Koyo Radiator - MSD Spark Plug Wires - Billet Power Steering Pulley - ARP Harmonic Balancer Bolt - Walbro 255hp in tank fuel pump - -6 Prolite Fuel Lines - Trickflow (black) fuel pressure regulator - Stainless Custom Dual Exhaust with X-pipe Drivetrain: - Dedicated Motorsports Shifter - Dedicated Motorsports Two Piece Driveshaft - Dedicated Motorsports Clutch Hydraulic Kit - LS7 Clutch and Steel Flywheel Suspension/Brakes: - KW Variant 3 coilovers - Hotchkis Sway Bars - New Front Ball Joints - FIGS Traction bars - FIGS Rear Toe links - FIGS Solid Steering Rack Bushings - Dedicated Motorsports Solid Diff Bushings - Dedicated Motorsports Spherical Rear Lower Control Arm Bushings - FIGS Supra Brake Rotor Brackets - DBA Slotted Rotors - Hawk HPS Pads - front and rear - Motul Brake Fuild Electronics: - HP Tuners Pro - Dakota Digital Tach Converter - Scan Gauge OBDII Reader - PLX Wideband Logging with HP Tuners - Pioneer 7 inch In Dash DVD player - Taylor Battery Box
