4000 quattro semi built racecar, saved from desruction as Lemons racer… Looooong way to go on build; Cage needs “upgrading” 20v turbo transplant running on E85 planned, 034 EFI, same front end geometry/suspension mods planned as implemented on my coupe, similar treatment to the rear…. etc, etc….
Now I gotta figure out how to get it outta the van and into my …
Got’s the turbo setup and moved the alternator to the passenger side, less obstruction in …
Front brackets bolt right in (for 22mm bar), had to put a plate behind it …
Got the front drop links together with my super custom brackets, 26mm bar is cleaned …
Had this stuff for a while… procrastinating working on the wiring!!!
Mounted on metal spacers, no more rubber bushings, removed reverse lockout frame…
Soo… I had to replace a bunch of OEM connectors because they were all broken, …
Ooooooops!!!! Kinda over did it on the camber mod… I can get a max of …
Front struts “done” coilover sleeves, bearings, ball joints… etc. knuckle modded for tons ‘o camber …
subframe urethane mounts a-arm urethane bushings front and rear 034 diff race mounts new CV …
pulled some B4 90 2piece struts I also got some CV’s in very good shape, …
cleaned up, “90” 2 piece struts, replaced bearings, cut off spring perch, converted to DIY …
The search for 2 piece struts starts now! converting front and rear to 2 piece …
over the last 4 months: later style dash and center console, soon to be installed, …
pulled rear diff, subframe, axles cleaned/painted refreshed, added urethane sub mounts, hard rubber diffmounts, replaced …
Fabbed up some aluminum door skins and plexi rear windows, finished painting the interior……
cleaned/pressure washed the whole drivetrain, cleaned, sanded and painted the rollcage and floor, wiring is …
