Started on Feb. 12 by jungle
1995 Volkswagen GTI VR6
1995 GTI VR6: 2.9l throttle body; mkIV head gasket; refurbished head; DSR 256 cams; shrick varible geometry intake manifold; S2 Metalwerks ceramic coated & port matched exhaust manifold & down pipe; high flow 2.5” Techtonics cat; Techtonics 2.5” cat back; Bilstien PSS9 Coil overs; Autotech front & rear sway bars; Autotech chassis brace, front, & rear strut tower brace; Autotech lightweight flywheel; Turn2 motor crank pulley; Quaiffe Limited Slip Diff; Stainless Steel Brake Lines; Poly bushings; custom GIAC chip; 167 SSR’s & 157 Team Dynamics
Add your comment
See more
JXspVVBw4OnNortuTvef8JScA6jxlVBxl6OlzRuzB0aQbMsQvXO6tNO3TXynsGAU
