1976 Datsun 280Z Chassis MSA Type3 Front bumper BetaMotorsports Carbon Hood ZCCJDM Rear wing Lexan Rear Hatch Window Motor Chevy Bowtie Block 383 stroker Eagle Forged Rods Weisco Forged Pistons Scat Forged Crank Dart Conquest Aluminum Heads I sky 530/550 Cam w/ Harland Sharp 1.5 roller rockers/valvetrain Cutler Intake Holley 1000CFM Tbody 42# injectors FAST EFI Fuel Injection Mcleod Bellhousing Cat LWFW Centerforce Clutch Kit Tilton Clutch Hydraulics Custom Exhaust system Drivetrain consists of: Tremec TKO 600 Roadrace transmission Custom 19inch drive shaft Infinity Q45 Rear LSD Speedway Engineering custom CV Axles and MML Axle adapters MML Forged Stub Axles Suspension is all monoball: Ground Control Coilovers Koni 8610 race struts QA1 Springs (various assortment) Ground control front camber plates AZ Zcar Rear Camber plates AZ Zcar rear cromoly control arms ZF Racing Front Control arms/TC Rods (My former company/ Design) Adjustable Rear Sway bar and non Adjustable Front Swaybar custom 5 lug conversion with Aluminim front hubs Brakes: Ford Mustang Cobra front and rear calipers/Wilwood TwoPiece Rotors Piper Motorsports cage UltraShield Driver’s seat FAST Digital Programmable Dash The weight is 2610 and the splits are 49% front and 51% rear. The car is VERY neutral in corner entry and hooks amazingly on corner exit. Car is making 450HP and 490# torque.
Bought this car for $6500 and I am tickled with how it’s coming along. It …
So we picked up a SPA technologies fire supression system and did the install a …
Just adding more shots. This weekend we’ll finish up installing the new fire system, prime …
You'll need to log in to post. Log in
