1973 Roadster with overdrive and aftermarket wheels.
Lotus Twin Cam
1958 MGA roadster, red with tan interior. 1500 engine stock, 4 speed . Converted to 12 volt, negative ground from 6 volt positive ground electrical system. Replaced generator with alternator. Installed stainless exhaust.
Stealth, fast.
Red, fast.
2011 Carrera 4s Coupe Style/Body Coupe 2-DR Engine 3.8L H6 DOHC 24V Manufacture Stuttgart, Germany
White, 2+2, 5 speed purchased new 160000 miles original interior (except front seats recovered) suspension reworked for auto crossing, with tower bracing, poly bushings Drilled & Slotted front rotors, with four (4) piston calipers (Toyota truck) lowered 1 1/2” 1973 …
Resting on jack stands, 4 cylinders, 2.0 l
IMSA racing body panels installed from factory. Updated 355 cu. in. engine and brakes, hubs and axles, subframe connectors added.. Custom made Weld wheels. Interior upgrades include A/C and alcantera seat inserts.
