There’s always something you can improve when it comes to classic cars. It doesn’t matter if you have a concours-grade car or a project that has yet to be started. The only difference is the length of that list and the degree of difficulty in checking off those boxes.
When we got my mother’s 1974 Cadillac Eldorado back out of my parents' garage after a decade-long dormancy, I started making a mental list. It’s only natural, right?
[Live thread: Bringing back a Cadillac that inspired a love of cars]
After 15 minutes (okay maybe longer), I stopped myself.
What am I looking to really achieve here?
That should be your first question before proceeding with any project. Everything else on your list should work toward that goal.
Are we going to concours with this Caddy? The car’s far from concours grade. Yeah, that’s too much time and money for me as of the moment.
Motorsports? A 1974 Cadillac isn’t exactly at the top of the performance heap, despite the 500-cubic-inch engine. Let’s forget that idea.
Eventually, I came to the conclusion that I’d like to preserve it, cruise with it when I’m back in town and maybe take it to local car shows. That’s it. That’s my happy spot. Yours could be different, and that’s okay. You do you. Just think it through.
Back to the Caddy, we needed to get it running to achieve my goal. Fortunately, the only things we had to do were fix a stuck left-rear brake drum and change the fluids. That’s it.
I recently took it to a highly regarded old-school mechanic who confirmed that the Caddy runs like a champ. He told me to just enjoy it.
Just enjoy it?! Is he crazy? Is that possible? Not for this overachiever!
Seriously, though, there’s some work to be done to get it a bit more presentable and roadworthy.
The convertible top is coming apart at the edges. This requires someone to guide the top as someone else–usually my brother, my father or my wife–works the electronic controls to drop it down. Annoying, but not the end of the world.
The chrome bumpers have some pitting and rust. Certainly ugly, especially up close. Pricy to fix? Most likely. Let’s wait.
Then there are the filler panels surrounding the lights that basically shattered when we moved the car out of the garage. Unsightly? Absolutely. Affects drivability? Not one bit.
Lastly, there’s a bent wheel (possibly more) from sitting on flat tires for years. This does affect how the car rides, keeps its hubcaps on and ultimately how I enjoy cruising around with it. Okay, this is next. It’s time to look for solutions.
While I do that, we’d love to hear what you got in the works for your classic sports car. Feel free to drop a comment and don’t forget photos. We love seeing your pride and joy.
I've had 25 years of pleasure from my '99 Mustang Cobra. A terrific local paintless dent removal specialist took three parking lot dings out of the car at modest cost several years ago. A couple of years ago the mice in our garage discovered that the pressure relief air vents in the trunk had a grid behind their flaps with rectangular openings exactly the cross-sectional area of a nickel, just mouse sized. They set up shop and the car smelled like it. Fixed the source by adding 1/2" hardware cloth behind the plastic grid, halving that cross sectional area and "closing the mouse doors". The odor remained.
Other than that, the only "drivability" issue was the original seats, with wear on the driver seat leather and not enough comfort for my spouse to enjoy a drive. Thorough cleaning and liberal use of Febreeze eliminated the odor after we removed all the old carpeting. Yesterday we finished installing new carpet on top of carefully fitted Dynamat sound absorbing material throughout the interior and trunk, and reinstalling the recently purchased primo Recaro seats with heat, ventilation fans, etc. She loves the Recaros, so that was a good investment. Not long ago put 4.10 gears in it so that 6800 rpm 4-valve engine could stretch its legs without sending me to jail. Yesterday's test drive was a joy.
Now that last "list" item: those 25-year-old chassis bushings. Already have nice, just slightly firm Bilsteins, but the bushings rattle a bit and jolt a bit too. After much agonizing about durability, control and ride comfort values, settled on the street-level Maximum Motorsports selection of urethane bushings as the most comfortable (lowest durometer numbers) option other than replacing factory rubber bushings that will dry out and fail again someday. Now have to get those installed, and hoping the driver's low back and his spouse's sensitive tush will still enjoy the toy. That's my list, hoping to end it with high satisfaction soon
The Maximum Motorsports street-oriented bushing options including the toe links for rear spindle conrol (much stiffer than the 1/2" dia stock links that flex and contribute to wheel hop) have been installed. Long, long job for the shop that did it, labor was $$$$. Much better, though ride is jiggly on rough surfaces. I have Bilstein B6 shocks on it, just slightly stiffer than stock shocks were. They are fine, unless there is an alternative better for these bushings. Wonder whether there is a better shock choice to pair with the MM urethane bushings to manage the high-frequency jiggle on slightly rough streets better.
Need to do more for wheel hop on 1st and 2nd gear hard starts, can't seem to get a smooth transition to mild wheel spin when wanted (despite decades of practice :-). Planning to add Billetflow IRS subframe (not the main rear chassis subframe) support brackets with their steel backing plates for best load spread on sheet metal next to the rear IRS subframe mounting point, and maybe MM's full-length welded subframe connectors, next. Without destroying the ride comfort, choices for wheel hop control are limited on this car. Converting to a solid rear axle is not on my menu. Haven't yet found an online comment reflecting a solution to this set of needs. Not a drag race car, and not a dedicated track car either, needs to be a GT car that is pleasant for cruising as well as fast and fun to launch from a stoplight. That's what I'm "really trying to achieve."
I've never heard of a steel wheel bending while sitting on a flat tire. I think it's improbable even in a much heavier vehicle thay the Caddy. I have had two tire blowouts at highway speed on flawed tires (same trip, I learned after the second one). The wheels didn't bend and only suffered some scuff marks where the wheels contacted the road surface while I was getting the car stopped.
Now, I'm quite aware of the date codes on tires, and won't leave town on a trip with old tires that look so new that they still have full tread and the factory "whiskers".
Replacement Caddy wheels should be available, or your wheel(s) could be straightened. In the meantime, a new wheel that fits your bolt pattern will keep you rolling.
Cheers, David
Cheers, David
David - thank you for the advice. Definitely bent some wheels in the past with the Caddy (10+ years on flat tires do a number). OEM steel wheels for that vintage of Caddy are not available like they used to be. You can certainly find refurbished ones, but with a wide range of conditions. My plan is get the wheels straightened and cleaned up this year.
Such good advice. I use the question of "what is my actual goal here" as a reality check. I'm currently very dedicatedly working to get my '70 Mustang back on the road (hopefully to bring to the Challenge next month) and I need that reminder nearly constantly. It's an extra struggle because I'm under a semi-artifical self-imposed deadline, but I also don't really want to cut any corners just to make it happen. And I'm also tempted to overdo things because I'm replacing so much stuff and installing so many new components, but I really just want it to be a fun and serviceable driver. So yeah, it really helps to ask that question of "what's the goal" to stop the project creep and recognize the difference between time, effort, and money well spent, and the pursuit of some while-I'm-in-there or because-I-can rabbit hole. That stuff still happens anyway, but it's at least somewhat mitigated even when it does. Old bolts and brackets get cleaned and painted instead of buying new stainless hardware. The pick-it-up-today generic parts store kit gets ordered instead of the 5-7 business day perfect, expensive, proprietary, fancy brand name version. Money and time are saved, and progress is made. And really, isn't that the goal?
Displaying 1-5 of 5 commentsView all comments on the CMS forums
