aussiesmg
aussiesmg SuperDork
1/9/11 4:01 p.m.
Do they fit? I have a chance on some BMW BBS rims real cheap, but do they fit onto a Camaro/S10?
5 x 120 = 5 x 4.75?
Does the center fit?
RealMiniDriver
RealMiniDriver Dork
1/9/11 4:10 p.m.
120mm = 4.724"
John Brown
John Brown SuperDork
1/9/11 4:12 p.m.
Some do some don't
Look at the hub diameter listed in here and compare to the wheels diameter.
The Beyern Mesh wheels I am buying will fit.
http://www.vehicle-bolt-pattern.com/chevy-lug-reference-guide.html
Crap. That is the wrong guide.
Camaro is 70.5mm
Junkyard_Dog
Junkyard_Dog Dork
1/9/11 6:03 p.m.
I had BMW wheels on My Camaro before I parted it. The PO drove it at speed but I wouldn't-the fit was close but not quite right. If you can get wobble lugs you should be OK.
AutoXR
AutoXR Reader
1/9/11 6:44 p.m.
yes they work fine
my vair
aussiesmg
aussiesmg SuperDork
1/9/11 8:06 p.m.
oh that's nice
Gimp
Gimp Dork
1/10/11 7:43 a.m.
My Camaro on my 318ti's wheels for moving it around purposes.
D_Howard
D_Howard Reader
8/20/12 4:49 p.m.
I know this is almost a year old thread but i'm looking into picking up a 1st gen s10 and am very interested in this. I'm looking to lower it 3" all around and was wondering if anyone can help me with which if any BMW wheels would fit, as I'm kinda lost with all the offset/backspacing stuff. Also can anyone learn me wobble bolts, can i run them with factory studs? Will they adapt the chevy s10 bolt pattern close enough that i can run BMW wheels? Am i better off going with adapters? I'm looking to get a good size wheel under this truck (19 or 20 inch), any additional info would be very much appreciated. Thanks.
mad_machine
mad_machine MegaDork
8/20/12 5:12 p.m.
somehow I missed that vair on the BBS rims... I used to run a chevy minispare on my Ti
Bobzilla
Bobzilla SuperDork
8/20/12 5:23 p.m.
5x120? That mean I could run some Acura RL wheels on my Vette? Since my vette wheels are 17x9.5 +56 and the RL's are 17x8 +50, I could run some snow tires/all seasons on it in the winter.
mad_machine
8/20/12 5:34 p.m.
I know the poke/stretch/stance crowd likes to put vette sawblades on their Bimmers
Bobzilla
Bobzilla SuperDork
8/20/12 5:48 p.m.
mad_machine wrote: I know the poke/stretch/stance crowd likes to put vette sawblades on their Bimmers
Seen that one. 17x9.5" wheel with a 225/45/17 tire on it. That is just wrong.
z31maniac
z31maniac PowerDork
8/20/12 6:01 p.m.
Yeah, but that's with MASSIVE adapters.
AngryCorvair
AngryCorvair PowerDork
8/20/12 7:01 p.m.
In reply to AutoXR:
dang, that looks like dave binnie's car, only in white. IIRC he had a very similar wheel -- E39 sport package circa 1997?
D_Howard
D_Howard Reader
8/20/12 9:52 p.m.
So from what I gathered if I use arp studs and adapters I shouldn't have a problem. But do I still need hubcentric rings?
z31maniac
z31maniac PowerDork
8/20/12 10:03 p.m.
D_Howard wrote: So from what I gathered if I use arp studs and adapters I shouldn't have a problem. But do I still need hubcentric rings?
Add in the cost and likely isn't cheap anymore.
D_Howard
D_Howard Reader
8/20/12 10:37 p.m.
The issue is less what's cheap and more the fact that if I go with any aftermarket wheels what's available is pretty much chrome torque thrust knock offs. I'm ok with paying a little more to get something in 18" to 20" that's more like BBS mesh wheels or something that looks more modern. I'm not into the old muscle car look on these trucks, I'd prefer something unique. Also in my area I've found multiple sets of BMW wheels with tires that have decent tread life for anywhere between $400-900 which on the lower end and factoring in adapters is better then the bad quality aftermarket+tires in that price range. I'd just like to know about the safety and fit issues. I would mostly be using the truck for around town commuting but I'd like to be able to be at highway speeds safely if I wanted to.
Feedyurhed
Feedyurhed Dork
8/21/12 4:57 a.m.
AutoXR wrote: yes they work fine my vair
Doh!!! Every time I see a nice looking Corvair I want one. I was just starting to get over it too and now this. Thanks. Off to CL.
z31maniac
z31maniac PowerDork
8/21/12 7:21 a.m.
D_Howard wrote: The issue is less what's cheap and more the fact that if I go with any aftermarket wheels what's available is pretty much chrome torque thrust knock offs. I'm ok with paying a little more to get something in 18" to 20" that's more like BBS mesh wheels or something that looks more modern. I'm not into the old muscle car look on these trucks, I'd prefer something unique. Also in my area I've found multiple sets of BMW wheels with tires that have decent tread life for anywhere between $400-900 which on the lower end and factoring in adapters is better then the bad quality aftermarket+tires in that price range. I'd just like to know about the safety and fit issues. I would mostly be using the truck for around town commuting but I'd like to be able to be at highway speeds safely if I wanted to.
Yep, just keep in mind quality studs + adapters will likely be in the $600 range.
Strike_Zero
Strike_Zero Dork
8/21/12 8:53 a.m.
There is a guy on BF.c that will cut some quality adapters with studs for ~$350 to mount Vette Sawblades on an E36 . . . Don't think you get 17x10 wheels anywhere else for ~5 bills on an E36
chandlerGTi
chandlerGTi HalfDork
8/21/12 3:50 p.m.
Strike_Zero wrote: There is a guy on BF.c that will cut some quality adapters with studs for ~$350 to mount Vette Sawblades on an E36 . . . Don't think you get 17x10 wheels anywhere else for ~5 bills on an E36
Yeah, he cut a set for the Volvo in my driveway. The big sawblades look kinda silly on a 850 wagon....
9MVdVrpddmHDIkArdVj4WhlxvJ5OefZ1DX0177SzQL5YiUgleC2a2IPBJZgKwsM0
