You’ve rebuilt the engine, redone the body, and
rejuvenated the suspension. Your latest restoration
project is ready for the open road, right?
Not always.
Sometimes the driving experience can still be
underwhelming–even miserable. Such was the case with our
Triumph TR6.
Ours is a very early 1969 model, and yes, it’s beautiful. This
Laurel Green car has been completely restored and outfitted
with just a few modifications: a tan leather interior, a Tourist
Trophy leather-wrapped steering wheel from Moss Motors,
72-spoke wire wheels fitted with Vredestein tires, and anti-roll
bars sourced from Good Parts. The stiffer springs came from
J.K. Jackson’s English Automotive.
Under the hood, the original, numbers-matching engine has
been completely rebuilt to nearly stock specifications. In the
interest of improving performance, while the engine was apart
we did a little bit of port-matching and shaved the head to
bump the compression ratio from 8.5:1 to 9.0:1. A Good Parts
mild street cam replaced the stock piece, too.
After all that work, however, our TR6 never ran that well. It
felt a bit lean, and its engine acted as if it were choked down–it
even missed a bit on occasion, especially at highway speeds.
There was work to be done.
To monitor our work, we packed up our TR6 and did some
testing at Balanced Performance Motorsports, a dyno shop
located just outside Atlanta. There we could run the engine in
a safe, controlled environment.
First, a baseline run. Triumph rated the factory engine at
106 horsepower, and we were pleasantly surprised at the initial
dyno results: 99.59 horsepower and 126 ft.-lbs. of torque at
the rear wheels.
Why were we happy to see less horsepower than the factory
promised? Driveline loss. Factory numbers record the power
made by the engine–and, depending on the year, with or
without the engine accessories. Once the car is put on a chassis dyno, driveline loss comes into play. As the engine’s power
moves through the transmission, rear end and other systems,
friction takes a bite.
A common rule of thumb is to expect a 15-percent driveline
loss. Following that logic, our car is doing better than stock–
and, in fact, most stock TR6s produce close to 85 horsepower
at the wheels.
With our baseline recorded, it was time to start making
improvements. First we reset the ignition timing, an easy fix. In
theory, the dyno would reveal the ideal setting. In our case, 36
degrees of total advance yielded the best performance: 100.2
horsepower at 5000 rpm.
Although we gained a bit more power, something still
wasn’t right. The car just didn’t drive as it should. Before our
test day, we identified a few specific areas that needed work:
carburetors, distributor and exhaust. Could fixing these three
weak spots cure our drivability ills?
Changing Carbs
The Stromberg carburetors found on many British sports
aren’t exactly universally loved, and that’s because they’re barely
adjustable. In fact, they pretty much only allow you to raise
and lower the needle, which fine-tunes the air/fuel mixture.
Sadly, the Strombergs fitted to 1968-’69 Triumphs are
no exception. These carbs were set to run very lean in
order to help the rather crude TR6 engine meet increasing
emission standards.
Raising our compression ratio, bumping up our timing, and
running a slightly hotter cam only made the problem worse.
The dyno said that we were running a bit lean, too, with an
air/fuel ratio just over 15:1 at higher rpm. Lean can be fast, as
it usually generates a bit more horsepower, but it can also be
dangerous. The engine runs hot, it starts to detonate, and then
bad things can happen. We needed to fix this problem.
The easiest solution on a TR6 is to replace the
Strombergs with older-style SU carburetors. There are other options–Webers, fuelinjection
conversions–but the SUs
bolt to both the TR6 manifold and
the original air cleaner. SUs are also
readily available, either new or used.
To keep the swap quick and clean,
we sourced a new set of SUs from
Moss. Their TR6 conversion kit retails
for a little less than $1000. You can
find used carbs at a swap meet or on
eBay for less money, but installing
worn-out, 50-year-old carbs may hurt
more than it helps.
We topped off these carbs with
some cool velocity stacks from The
Winner’s Circle that fit perfectly
inside the stock air-cleaner housing.
Running velocity stacks smoothes the
airflow into the carburetors and can
make a difference in power. Installing
the SU carburetors was a very
straightforward, hour-long project.
Installing a Rebuilt Distributor
As a vehicle puts on years and
miles, its distributor begins to wear. It
can rotate unevenly and cause a miss,
especially at higher rpm.
Advanced Distributors rebuilds
older distributors, including all of the
popular Lucas units fitted to these older British cars, to as-new
condition. Figure most of their Lucas rebuilds start somewhere
between $130 and $200.
We ordered a Lucas distributor that had been rebuilt,
recurved and fitted with just a mechanical advance. Most
distributors have both centrifugal and vacuum advances.
Using just the centrifugal makes more controllable power, as
the vacuum advance doesn’t kick in when it’s not wanted.
Factory advance curves are often a compromise between
performance, drivability and emissions. Considering our
slightly higher compression, desire for maximum performance,
and use of premium fuel, we asked Advanced Distributors to
bring in full advance by about 2500 rpm.
After receiving our new distributor, we replaced the stock
points and condenser with a Pertronix ignitor–about $100 for
the parts and just a few minutes to install. This system uses
rotating cobalt magnets to create a Hall effect to trigger the
ignition. Once set, this ignition doesn’t require any adjustment.
We’ve used Pertronix ignitors on most of our project cars for
years and have had very good luck with them.
Upgrading the Exhaust
The final step in our TR6 modification involved the exhaust.
What goes in and gets ignited must come out, right?
An early TR6 like ours uses a cast-iron exhaust manifold
paired with a single exhaust system. Starting in 1972, most
likely to reclaim some power lost
to the lower compression ratio
introduced that year, the TR6
received a dual exhaust manifold.
That twin-pipe manifold was met by
twin exhaust pipes.
According to the Triumph
community, the dual-exhaust system
offers more performance. We found
a used 1972-and-up manifold and
ordered the later exhaust system
from Moss Motors.
Actually, we ordered a pair of
systems from them: their stock
replacement as well as the all-stainless
Tourist Trophy model. To mount
either of these systems to an early
TR6, you’ll need the corresponding
late-style exhaust hanger bracket that
attaches to the transmission.
The Tourist Trophy model is
beautiful. The fit, finish and design
make it unquestionably nicer than
the stock replacement. And with
a list price of $569.95, the Tourist
Trophy exhaust only costs about $30
more. It’s a no-brainer.
We tried both systems, and while slightly louder than stock,
the Tourist Trophy system delivers a very pleasing exhaust
note. We didn’t find it objectionable for high-speed touring,
either. It’s the one we kept on the car.
The Dyno Does Lie
We always tell folks that the dyno doesn’t lie, but in this case
it did. Well, we’ll explain.
Our peak numbers didn’t change. Despite all of the work,
the engine’s max horsepower remained constant. At wideopen
throttle, the engine still made the same horsepower
peak, with 2 or 3 more horsepower produced in the meat of
the powerband.
Here’s the big improvement, though: Our TR6 now drives
so much better than before. It has simply come alive. The
hesitation, ignition-missing and general lack of zing have been
banished. It starts easily, warms up quickly, revs nicely, and
runs flawlessly in all conditions and at all speeds. Our once sour
TR6 is now an absolute joy to drive.
So what made the difference? Our worn-out distributor
certainly wasn’t helping, so replacing it with a rebuilt unit was
a must. Plus, the new carburetors work better with our slightly
warmed-over engine. And that Tourist Trophy exhaust delivers
the perfect note for a classic sports car. Finally, our TR6 runs
as good as it looks.
More like this
Gary
Dork
8/31/15 8:36 p.m.
This was an excellent article in a very good issue and prompted me to renew my subscription.
https://classicmotorsports.com/forum/classic-cars/july-2015-issue/102325/page1/
Do you have any pictures of the finished installation so I can see the routing of the hoses?
This was a while back. David might have some additional pics.
Displaying 1-3 of 3 commentsView all comments on the CMS forums
