DukeOfUndersteer
DukeOfUndersteer Dork
10/28/09 8:44 a.m.
Not Mine...
i am selling 944 porsche 1983, car need clutch, for the age car is in good clean condition, original wheels, 1000.00 or best offer, car located in lilburn. 770-616-0223
http://atlanta.craigslist.org/atl/cto/1440820786.html
dean1484
dean1484 Dork
10/28/09 6:56 p.m.
Original wheels? To him may be.
JThw8
JThw8 SuperDork
10/28/09 9:02 p.m.
maybe he meant to say it would come with the original wheels and not those ones.
maroon92
maroon92 SuperDork
10/28/09 9:36 p.m.
not sure it is worth it. A clutch job would cost a normal person nearly 1000 dollars, and I am sure that needs more than a clutch.
John Brown
John Brown SuperDork
10/29/09 6:24 a.m.
Now Maroon, if you can find me one that is that clean for less... you know my number ;)
maroon92
maroon92 SuperDork
10/29/09 7:18 a.m.
okay John.
As a parts car, it is probably worth it, you should be able to make about 3 grand off of it if you do it well, but as a driver, you would not even be able to make it run right for Challenge money (unless you got him to lower the price a bit. I would offer 500 and see if he bites)
AngryCorvair
AngryCorvair SuperDork
10/29/09 8:27 a.m.
maps dot google dot com
directions
charlotte nc to lilburn ga
AngryCorvair
10/29/09 8:29 a.m.
In reply to AngryCorvair:
awesome! about 5 miles NNW of Lilburn is Berkeley Lake. Does google maps use the same filters as the GRM board?
DukeOfUndersteer
10/29/09 8:39 a.m.
its close to E36 M3 highway
16vCorey
16vCorey SuperDork
10/29/09 10:24 a.m.
maroon92 wrote: not sure it is worth it. A clutch job would cost a normal person nearly 1000 dollars, and I am sure that needs more than a clutch.
Why? If you shop around you can get a clutch kit for a little more than $500. Add a Saturday of wrenching and you've got a running 944 for $1,600 or so. Why are you so sure it needs more than a clutch? The crappy rubber hub on the stock clutches is all that usually goes wrong with them. When I did mine I cheaped out and just changed the clutch disk with a sprung-hub unit and changed the TO bearing (it was a little noisey). I was back up and running for less than $300.
maroon92
maroon92 SuperDork
10/31/09 5:14 p.m.
hmmm...I do get an employee discount!
JetMech
JetMech New Reader
11/1/09 12:50 a.m.
If I lived in that area, that 944 would look like a possible $2010 Challenger...but, I'm clear across the country.
vnBanh5e5FLDyacCojJDRzybZMSx5aVFa42K4OAi2LjA5U5aB98rxF2k5VD5EcyY
