2 3 4 5
Lof8 - Andy
Lof8 - Andy UltraDork
4/2/24 8:19 a.m.
lookin good!
4/2/24 8:23 a.m.
In reply to dyintorace :
Don't use the harness addressed to Angry Corvair! 🤣
dyintorace
dyintorace UltimaDork
4/2/24 8:42 a.m.
You didn't specify that!
dyintorace
4/2/24 8:44 a.m.
We also have plastic overfenders we want to add. The front fenders may require additional "clearance-ing" based on tire size.
wvumtnbkr
wvumtnbkr PowerDork
4/2/24 9:07 a.m.
You don't need the fan or oil cooler for the challenge.  Those can be taken off the list if time is critical.
Stampie
Stampie MegaDork
4/2/24 9:36 a.m.
In reply to wvumtnbkr :
The fan is "works" but I'd like to add a relay.  The fuse box, battery, headlight/fan connection, and relays will be within a foot of each other.  Not a big rewire.  Right now the trans sits with the trans cooler lines just cut 6 inches from the trans.  Adding a cooler will only take slightly longer than doing a loop on them and I'd rather have a cooler for a 4L60E.
Stampie
Stampie MegaDork
4/2/24 2:42 p.m.
Headlights procured in case needed.
Just to prove Mr_Asa wrong I got them off a Ford. Pretty sure it was undeserving of them.
dyintorace
4/3/24 2:17 p.m.
Made some progress last night.
  • Starter wire from switch panel to starter lengthened
  • Starter installed
  • Trans cooler lines installed
  • Passenger O2 sensor installed
  • Rollbar installed
  • Battery (re)installed
  • PCM mounting started
  • Wheels pulled for tire mounting tonight
wvumtnbkr
wvumtnbkr PowerDork
4/3/24 3:13 p.m.
This sounds like it's not going to be much of a PLB (which is fine as well).
Yall are making great progress!
MrJoshua
MrJoshua UltimaDork
4/3/24 3:54 p.m.
Just the gigantic scary stuff left-Will it run?
dyintorace
4/3/24 5:12 p.m.
It feels like there is still a LOT to do so don't worry!
dyintorace
4/4/24 6:32 a.m.
A huge shoutout to a_florida_man for mounting our tires last night!!
a_florida_man
a_florida_man Dork
4/4/24 8:14 a.m.
Who let the old fat grey haired guy into my garage to use the tire machine?
dyintorace
4/4/24 9:01 a.m.
No clue but he's great to hang out with!
Stampie
Stampie MegaDork
4/4/24 9:20 a.m.
Better question is what the hell is he doing to that tire?
a_florida_man
a_florida_man Dork
4/4/24 10:06 a.m.
In reply to Stampie :
Trying to find the hole?
Stampie
Stampie MegaDork
4/5/24 9:22 a.m.
Getting ready to load up and head to the hotel.
4/5/24 11:08 a.m.
He looks like he's mounting that tire in the Biblical sense.
Byrneon27
Byrneon27 HalfDork
4/5/24 11:28 a.m.
^ Sometimes you gotta hump 'em into submission
dyintorace
4/5/24 11:29 a.m.
dyintorace
4/5/24 11:30 a.m.
We're set up and getting to work!
wvumtnbkr
wvumtnbkr PowerDork
4/5/24 11:58 a.m.
I'll be down in a bit.  Just finishing my build book and trying to print off 1 thing I forgot.
Dusterbd13-michael
Dusterbd13-michael MegaDork
4/5/24 12:22 p.m.
We're supposed to hit the parking lot at 1:20 p.m.. I will drop your box of engine management parts and air filter parts and then the munchkin and I are getting lunch. My fat ass is hungry
dyintorace
4/5/24 1:22 p.m.
Stampie
Stampie MegaDork
4/5/24 1:30 p.m.
2 3 4 5
70R8wD4QTdIBUbW09QhpEbQ236ihvyPSytBNUhEEnyY3zwUMo3pV14PXekI10y40
