PoisonousBeef
PoisonousBeef New Reader
9/10/09 12:16 p.m.
1985 S-10 Blazer 189k Miles 2.8 V6, 5-Spd, 4x4 Located in Butler, PA (16001) @ JTech Sales & Service
Price: $550 (firm)
Info Bought this a while ago because I wanted it for winter, but I have half a dozen projects that are ahead of this and I won't get to it before snow falls. It starts right up and the motor sounds fine. As you can see the body is hurting, though the truck was Ziebarted, so the rocker boxes on the cab are actually real clean. Worst part of the body (IMO) is above the rear window, as the hinge attachment point is gone. Former owner just used putty but bottom line is it needs some steel welded in there. Frame looked good at a glance, though one front cab mount (the cup on the cab, not the frame attachment point) looks questionable.
Needs Clutch (or maybe just a slave? I literally haven't touched it) Body work
FAQ Will the truck drive? No. The clutch is totally non-functional. Could be as easy as a slave, could need a whole clutch kit, I do not know and don't plan to find out. The truck starts and runs but will not move itself. It does roll freely as 2 of us pushed it around the lot at JTech so nothing is frozen up.
Will you part this out? Not yet. If it's still around in a month then I'll consider it.
Are you interested in trades? Not especially, as I have enough projects, but it's possible.
Is the price negotiable? No. I have more than that in the truck, I'm just cutting my losses.
Do you have the title? Yes. The clear title is currently held by JTech under the dealer license and Jason can transfer the title to you at the local notary, which is 2 minutes away.
Can you deliver the truck in the area? You can arrange flatbed delivery with Jason @ JTech. You will have to discuss the rate with him, though he is generally inexpensive by comparison to other outfits.
Photobucket Photobucket Photobucket Photobucket Photobucket Photobucket Photobucket Photobucket Photobucket Photobucket Photobucket
HeavyDuty
HeavyDuty Reader
9/10/09 1:50 p.m.
I think what you mean is some girly guy (you) and some big strong guy (me) pushed it around the lot.
Bump for you to fix your pics. Please get this beast away from my 83 Blazer. I don't want the rust to spread to my winter ride.
F8H20k0CgFCiquwSV7mV8Ah8SuodgcxWIGARNYZZ0sIQ7ykiH6MBTILdtNmAliif
