madmrak351
madmrak351 HalfDork
2/17/24 12:14 p.m.
I was given these tube remnants from a cage installation on a friend’s 350z. The tubes are 1.5od. The longest one is 46”. Also there are 1/8 by 6x6 mount plates quantity of 7. I propose a FMV of $25.
madmrak351
madmrak351 HalfDork
2/17/24 12:18 p.m.
Leftovers from a cage install on my friend's 350z. Tube is 1-1/2 od longest tube is 46". Also included quantity of7 1/8x6x6 mounting plates. I propose $25 FMV. What do you all think?
Edit  tube outside diameter is 1-5/8.
2/17/24 3:44 p.m.
Weigh it. My local steel shop sells "usable drops" for $1/lb
Stampie
Stampie MegaDork
2/17/24 7:05 p.m.
I think I shop at the same place as AC so I'm good at $1/lb.
madmrak351
madmrak351 HalfDork
2/18/24 5:06 p.m.
Ok so here are the usable pieces as I see it at this point. I am at 40lbs. I do not see myself using the very short pieces at this point, if that changed I could add them at the rate of $1 per pound. So out of this lot I could budget what I used at $1 per pound. This lot would be considered "usable drops". This is my proposal for FMV.
madmrak351
madmrak351 HalfDork
2/18/24 5:07 p.m.
Racebrick
Racebrick HalfDork
2/18/24 5:09 p.m.
I agree with $1 per pound.
gumby
gumby Dork
2/18/24 6:15 p.m.
Yikes. When I built Brad my Drop Shop was $0.60/lb. I just checked their website; $1.05/lb for steel!
Budget $1/lb, and I'll swear to it.
Stampie
Stampie MegaDork
2/18/24 6:28 p.m.
In reply to madmrak351 :
Just weigh what you use as you use it and budget it that way.
2/18/24 8:02 p.m.
Exactly. Only charge your budget what actually ends up on the car.
madmrak351
madmrak351 HalfDork
2/19/24 11:34 a.m.
Thanks Gentlemen, that makes four. I need one more in agreement, please.
gumby
gumby Dork
2/19/24 12:23 p.m.
You don't need forum approval to use corporate pricing as FMV.
https://www.warnersteel.com/
Scroll down to Drop Shop. Use Warner, or document your own drop steel prices locally. Done.
madmrak351
madmrak351 HalfDork
2/19/24 12:40 p.m.
In reply to gumby :
Thanks!
sXOZizbWzuykqn8mE0r0WXD7oczNRY40gL3voPIdqORfNSFSkb4E6yuVnqPNtFef
