cagedbunny
cagedbunny New Reader
9/8/08 8:19 p.m.
As much as I'd love to keep this, I need to slim down the number of cars in front of my house. '84 Rabbit GTi race car (Improved Touring B class.) Full SCCA Log-book. Cashmere white, originally blue interior. Non sunroof car, a/c deleted completely. Here are the specs;
Rebuilt JH motor. Only 6 races on the rebuilt motor. Strong motor, runs very well with no issues. Group A headgasket -G-grind cam -windage tray -Techtonics 4-to-1 race header, custom exhaust with a Supertrapp. Comes with a second exhaust as well (custom pipe to turn-down) -F+S heavy duty clutch -lightweight flywheel -All poly motor mounts
-poly control arm bushings -poly rear beam bushings -Shine Racing spherical rear upper shock mounts -Shine Racing bolt-in camber plates -Autotech 28mm rear sway bar -16v Scirocco lower 4pt brace (front) -H+R lowering springs -poly rack bushings -SS brake lines all around -Hawk pads (track compound)
-full Kirk Racing bolt in roll cage, with additional welded in dash bar. Removeable door bars.
-Momo Start racing seat (driver's side.) Original passenger seat is also included, and in near mint condition (blue) -Grant steering wheel -Simpson 5pt harness -VDO gauges -Wink panel mirror + additional blind-spot mirror -removeable window net -ignition kill switch on dash
Tons of new parts as well - All wheel bearings and hubs have been replaced, new radiator, injectors+o-rings, drums, balljoints, etc. The car runs extremely well; I drove it back from Florida with no issues, and have since competed with it in a local 24 hour auto-x (very competitive, and again; absolutely no issues.)
The body is in good shape overall, but not perfect. The spare tire carrier has some rust in it, but is still structurally sound (carried my jack/tools, and a cooler to the auto-x and back without issue.) The only other rust is under the taillights, and on the rear valence. To have ever been a race car, the body is in really good shape.
There are only a couple things that the car could benefit from; a set of tires (current tires are old and dry-rotted), and a set of shocks. The current shocks are fairly dead; a set of off-the-shelf Bilsteins would do wonders for the car. The rear swaybar is currently not installed, but all brackets/hardware are included. The passenger-rear bumper cap is also missing, but an easy fix, and just a cosmetic annoyance.
The speedo-cable has been removed, and like most Mk1 clusters, the tach works when it feels like it. All other gauges work as they should. The car maintains excellent oil pressure, very low oil and water temps, and runs like a raped ape.
With a set of tires, and a front end alignment, I honestly would not hesitate to drive this car anywhere. It's been drop-dead reliable, and an absolute blast to drive.
[img]http://img.photobucket.com/albums/v165/GTiRacer53/stuff%20FS/P1010639.jpg[/img] [img]http://img.photobucket.com/albums/v165/GTiRacer53/stuff%20FS/P1010640.jpg[/img] [img]http://img.photobucket.com/albums/v165/GTiRacer53/stuff%20FS/P1010641.jpg[/img] [img]http://img.photobucket.com/albums/v165/GTiRacer53/stuff%20FS/P1010642.jpg[/img] [img]http://img.photobucket.com/albums/v165/GTiRacer53/stuff%20FS/P1010650.jpg[/img] [img]http://img.photobucket.com/albums/v165/GTiRacer53/stuff%20FS/P1010643.jpg[/img] [img]http://img.photobucket.com/albums/v165/GTiRacer53/stuff%20FS/P1010644.jpg[/img]
Rust:
[img]http://img.photobucket.com/albums/v165/GTiRacer53/stuff%20FS/P1010645.jpg[/img] [img]http://img.photobucket.com/albums/v165/GTiRacer53/stuff%20FS/P1010646.jpg[/img] [img]http://img.photobucket.com/albums/v165/GTiRacer53/stuff%20FS/P1010647.jpg[/img] [img]http://img.photobucket.com/albums/v165/GTiRacer53/stuff%20FS/P1010648.jpg[/img] [img]http://img.photobucket.com/albums/v165/GTiRacer53/stuff%20FS/P1010660.jpg[/img]
[img]http://img.photobucket.com/albums/v165/GTiRacer53/stuff%20FS/P1010649.jpg[/img] [img]http://img.photobucket.com/albums/v165/GTiRacer53/stuff%20FS/P1010651.jpg[/img] [img]http://img.photobucket.com/albums/v165/GTiRacer53/stuff%20FS/P1010652.jpg[/img] [img]http://img.photobucket.com/albums/v165/GTiRacer53/stuff%20FS/P1010653.jpg[/img] [img]http://img.photobucket.com/albums/v165/GTiRacer53/stuff%20FS/P1010654.jpg[/img]
The wires are for the additional gauges; [img]http://img.photobucket.com/albums/v165/GTiRacer53/stuff%20FS/P1010656.jpg[/img] [img]http://img.photobucket.com/albums/v165/GTiRacer53/stuff%20FS/P1010658.jpg[/img] [img]http://img.photobucket.com/albums/v165/GTiRacer53/stuff%20FS/P1010659.jpg[/img] [img]http://img.photobucket.com/albums/v165/GTiRacer53/stuff%20FS/P1010661.jpg[/img] [img]http://img.photobucket.com/albums/v165/GTiRacer53/stuff%20FS/P1010662.jpg[/img]
Extras; [img]http://img.photobucket.com/albums/v165/GTiRacer53/stuff%20FS/P1010664.jpg[/img]
Pics from the 24 hour auto-x a couple weekends ago;
[img]http://img.photobucket.com/albums/v165/GTiRacer53/GTi%20stuff/DSC05578.jpg[/img]
[img]http://img.photobucket.com/albums/v165/GTiRacer53/GTi%20stuff/DSC05584.jpg[/img]
[img]http://img.photobucket.com/albums/v165/GTiRacer53/GTi%20stuff/DSC05586.jpg[/img]
[img]http://img.photobucket.com/albums/v165/GTiRacer53/GTi%20stuff/DSC05587.jpg[/img]
filthy, but you get the idea; [img]http://img.photobucket.com/albums/v165/GTiRacer53/GTi%20stuff/P1010638.jpg[/img]
[img]http://img.photobucket.com/albums/v165/GTiRacer53/GTi%20stuff/DSC05593.jpg[/img]
[img]http://img.photobucket.com/albums/v165/GTiRacer53/GTi%20stuff/DSC05603.jpg[/img]
[img]http://img.photobucket.com/albums/v165/GTiRacer53/GTi%20stuff/DSC05606.jpg[/img]
does not come with Kosei wheels pictured above Those were borrowed from a friend for the auto-x. The car will come with a set of black snowflake wheels.
[B]$1800.[/B] Title is clean and clear. Located in Charlotte, NC
cagedbunny
9/8/08 8:21 p.m.
Bah, I always forget the picture format is a little different here. Check out this thread on VWVortex for all the pics;
http://forums.vwvortex.com/zerothread?id=4014411
savestheday
savestheday New Reader
9/8/08 9:47 p.m.
We need to work something out on this!!
CarKid1989
CarKid1989 New Reader
9/9/08 7:30 a.m.
Can i buy just the seat?
cagedbunny
9/9/08 9:56 a.m.
The passenger seat; yes. But the driver's seat is staying with the car.
jwdmotorsports
jwdmotorsports Reader
9/10/08 5:56 p.m.
Trade for an unfinished V8 RX7?
cagedbunny
9/10/08 10:17 p.m.
Not looking for any trades. As is, I've got too many cars/projects; trying to narrow down the fleet!
maroon92
maroon92 SuperDork
9/10/08 10:48 p.m.
man, that looks awesome. I wish I had the cash, I would drive that daily.
cagedbunny
9/12/08 9:05 p.m.
SOLD!
dknk58kbvOgj8wsOr4cnpeUFYxKY9AdGHdK36H7UuUCcBRDRua8dXOa4HCEp2YbE
