9/2/20 4:14 p.m.
Anybody got a relatively short 3/8" heim-jointed tie rod slash turnbuckle slash length adjuster slash whatever you want to call it? I need one for MonZora's alternator belt tensioner.  My target length (for this assembly!) is about 6-7". Yeah, I know, pretty short.
Speedway has Swedged tubes 4" long for $9, then a LH and a RH 3/8" male heim are $4 each, so I'd be into a new assembly $17 plus whatever part of tax and shipping hits the budget. Was hoping someone would want to sell me one cheap or trade me for a chunk of Corvair trunk floor or something dumb like that.
help a brother out!
thanks!
Stefan (Forum Supporter)
Stefan (Forum Supporter) MegaDork
9/2/20 4:28 p.m.
You mean like the ones they use on a 944 to adjust the power steering and air compressor pump?
https://www.ebay.com/itm/87-89-PORSCHE-944-POWER-STEERING-PUMP-A-C-ALTERNATOR-BELT-TENSIONER-OEM/203076579131?hash=item2f484eaf3b:g:sdUAAOSwWVxfNh~d
They aren't cheap, but maybe someone has one laying around from a manual conversion or similar.
9/2/20 4:39 p.m.
Same concept, slightly different execution.
browny333
browny333 New Spammer
9/2/20 5:54 p.m.
you may find it at the following [canoeing] site
matthewmcl (Forum Supporter)
matthewmcl (Forum Supporter) Reader
9/2/20 6:21 p.m.
I almost had something, but they are 5/16 and both right hand thread on all thread (adjust and then install).
Since this is a challenge car, can you use a hardware store turnbuckle with eyelets?
https://www.homedepot.com/p/Everbilt-3-16-in-x-5-1-2-in-Zinc-Plated-Turnbuckle-Eye-Eye-807006/204273923
Patrick (Forum Supporter)
9/2/20 7:24 p.m.
Look for lawn tractor parts, i have found them a good source of pieces like this
NOT A TA
NOT A TA SuperDork
9/2/20 7:39 p.m.
Would one of these work? Might have to modify the ends or replace for your application. But hey you've been developing mad fab skills!  I have one a customer marked up the paint on the end of by tightening a nut. He then returned it and asked if I could make a custom one with different proportions to fit his custom application, which I did. I've changed the product slightly and don't offer it in gloss enamel anymore so it's been sitting on a shelf. I'd be proud to donate it to the project. 3/8" left & right thread all thread rod with right/left thread center section with right/left locking nuts.
https://lab-14.myshopify.com/products/adjustable-upper-control-arm-shaft-mounting-bolt-brace-for-use-with-g-braces
RacetruckRon
RacetruckRon Dork
9/2/20 8:28 p.m.
Let me check the bin of misfit McMaster parts. I have some stuff leftover from my scrapped remote shifter project.
9/2/20 8:36 p.m.
I used Midwest-Control the last time I had to buy rose joints.  Cheaper than some of the other options at the time.
a left and right hand tap can't be too expensive along with a piece of tubing.
Better idea:  cheap strut tower brace, cut it down keeping the reverse thread side.  Drill and tap cut off side to fit the other joint.  Done.
wawazat
wawazat Dork
9/2/20 8:58 p.m.
Hardware store turnbuckle with eyes bushed for tight fit on your fasteners?
9/2/20 9:53 p.m.
In reply to NOT A TA :
Donate it?!?! That's exactly my price! I'll cover shipping for sure. Will probably be the only Challenge car with Lab-14 parts!  :-)
Thank you!
NOT A TA
NOT A TA SuperDork
9/2/20 10:38 p.m.
Thank you!
Send me an email with full name & shipping address. laboratoryfourteen@Gmail.com. It's under the USPS first class weight limit so cheap to ship.
9/2/20 10:54 p.m.
Done. Thanks again!!!
NOT A TA
NOT A TA SuperDork
9/2/20 11:59 p.m.
Packed & labeled, will go out in the AM.
9/18/20 10:57 a.m.
Special thanks to NOTATA and Racetruck Ron for their kindness. Starting with:
I did this:
then I did this:
followed by drilling out about 3/4" of the RH female thread and welding on one of the jam nuts, which allowed me to do this:
IJK5XnS2CKGhfZz60289sU0WNTyuIcGIPUuyOmfvjFX2MttjWdEZtLRjVdmx6mwX
