Pinche_Chingadera
Pinche_Chingadera New Reader
11/18/08 9:26 p.m.
I got this last year for christmas and used it twice. I'm just not out in the garage like I used to be. If your local then I've got a full tank of straight argon in a 80CF tank from Airgas.
Designed for Light Duty STICK ( SMAW or CC ) Welding. 1/16" and 3/32" E6013 Electrodes. 1/16" and 3/32" Stainless Steel Electrodes. Scratch Start TIG Welding. Output Range of 10 to 80 Amps. Welds Material up to 1/8". Plugs into Standard 115 VAC Receptacle. Only Requires 20 Amps Circuit. 25mm Twist Lock Output Terminals . Rugged output terminals allow easy polarity reversal and cable changes. Heavy Duty 6 Gauge Welding Cables. 15 ft. Electrode Cable and Tweco Brand Electrode Holder. 10 ft. Work ( Ground ) Cable and Rugged Clamp. Thermal Overload Protection. Protective Case TIG Kit: 12.5' Air Cooled TIG Torch w/ valve, accessory kit, 10 ft. gas hose regulator, and attached dinse connectors.
Like I said if your local I've got a 80CF tank of straight argon that basically full as I used the TIG about 3 minutes and didn't have the regulator opened up much. Also comes with a pack of filler rods. So if your local this would be a ready to TIG weld setup. 350 picked up with tank or 300 shipped for just the welder. I'm located in Neenah WI for those interested in picking it up. Email addy is Hndphilemon@tds.net is the fastest way to get ahold of me.
Pinche_Chingadera
11/22/08 7:10 a.m.
I'm up for all offers, trades whatever. If you just happen to have a basketcase BSA project sitting in the corner of your garage I'd be up for that. Preferably a 650 Thunderbolt.
HoZy6p92JEU6ctHJhgglXJ5Ku1moiS6m8M57AvoT7Io0hSIOYia7CX0kWkB85iLA
