Hey guys, I am looking for a set of 13" rims with a 4x114.3mm bolt pattern (er, I think I mean 4x 4 1/2" for you states folk ). The offset needs to be for a fwd car, so 35mm-45mm. I'd prefer for them to be wider then 5.5" as I will be mounting a brand new set of 205/60R13 Toyo RA1's on them.
Have to be willing to ship to Canada Thanks guys.
got a set of steel wheels but I think they are only 5" wide but I have mounted on a set of 205/6013 tires and they fit perfect. My set of rims were originally on a te72 corolla
let me know if you are interested
http://losangeles.craigslist.org/lac/pts/1328911242.html
I've got some 13" 4.5" pattern MRT 3 piece aluminum wheels here.
13" x 7" 32mm offset
13" x 6 " 20mm offset, you could probably get ~12mm more offset if you run the center on the outside of the hoops (it's sammiched in between the two hoops right as it is right now)
I can get pics / price if you are interested.
I have no problem shipping to Canada providing you are ok with what ever the shipping ends up being. They are sexy 3 piece aluminum wheels.... not like they weigh a ton :D
We have some 10" wide ones if you want to go reeeal crazy...
Got some new and used Hoosier race rubber too, just throwin it out there.
I'd be interested in hearing the price for these that you are looking for. I can be reached at aevokes AT shaw D0T ca (if you want to send me your e-mail addy) so I can give you my shipping address to check out shipping charges. Also what would be really cool is if I could get measurements from the back of the lip of the rim to the backside of the "hub" of the rim (the part that mounts against and flush with the hub assembly on the car, I am sure you know what I mean). Thanks
If my math is correct the distance from the inner rim lip to the mounting face should be right around 5" for the 7" rim (3.5" center line + 1.25"ish offset + .25ish rim lip width). I'll be at the garage tomorrow, I'll get you all the exact specs/pics/pricing.
