Not mine, etc...
http://hartford.craigslist.org/cto/4485827340.html
Dirt Cheap good ol boy thrills, had a baby boy three weeks ago and I have too many project cars..
1979 Plymouth Fire Arrow
Engine: 1600cc 4g32 Chain Drive Ported Head by Keith Black's shop Comp Cams built to C2 Rally Spec Dual Weber Side Drafts (40DCOE with Ram Flo's) Equal-length header, 2.5 in exhaust with new thrush muffler Accel 300+ Digital Multispark Ignition with built in rev limiter (adjustable) Accel Hi-Temp Super Stock Radio Suppresion 8mm Ignition Wires NGK Iridium Plugs Battery Relocated (to Rear of car) Tachometer Voltmeter Oil Pressure Gauge Fuel Level Gauge Fuel Pressure Gauge Water Temp Gauge Oil Filter Relocate Holley Fuel Pump
Handles: Aftermarket Suspension built to C2 Rally Spec Rear Disc Brake Conversion Welded Differential Rip Stick Adjustable Brake Bias
Body: Roll Cage, R.J.S 4 pt racing harness Skid plates for Engine and gas tank Gutted/Plexiglass Windows 4 Baja Rally Lamps (selectable)
New radiator, new brake pads, new pulleys, had valves reseated, engine has new gaskets, had weber's ultrasonic reduced and the jets were swapped, put in the digital ignition system... Also, the plastic gas pedal broke and has been replaced with an alum bass kick pedal from a pearl drumset Car is a blast to drive, you can't kill the thing. I have 3 Haynes manuals for maintenance; easiest car I've ever worked on. The car still has an SCCA logbook from when it was a stage car, but all the safety gear needs to be updated before it can stage again.
Car comes with a bunch of spare parts; the major stuff is: An Engine, a transmission (gears are good), a spare axle, a spare differential, spare pistons and connecting rods, 4 studded winter tires/rims, two spare rally tires/rims, spare EQ Length header.
The car needs to have a garage at its new home and an owner who isn't afraid of resto-work and tinkering. If you would like to ride/drive along, we can set up a date and I will bet you money it will put a smile on your face.
$1650. (Email for ride along at PSCCNY JUNE 1)
more pictures can be found here:
http://www.ner.org/forums/index.php/topic,3087.msg23388.html#msg23388
