Name-Caleb
location-Brookneal VA 24528
Contact-4349074807 or maxey01@lynchburg.net
Price 800$ OBO
Well guys its time to part ways with my mr2,I cracked a piston and i just don't have the time or energy to replace or rebuild. So here's the basic run down.
Body
-1985 hardtop
-212,678 miles on body
-87+ side skirts
-interior has fatmat,isolating foam, and MLV on floors and firewall
-Twosrus engine cover prop
-15x6 enkei wheels with good condition 205/50/15's
-Previous owner rebuilt trans
-Clutch replaced
-Braided Clutch line
-Fuel pump replaced
Suspension
-Full Prothane bushing set installed
-Custom sprung BC Racing Coilovers 200-F 350-F
-All new ball joints
-Steering rack rebuild (new inner,outer tierods,regreased, and bushings replaced)
-New front sway bar links
-New Rear wheel bearings
Brakes
-Upgraded to 87+ brakes all the way around
-Brembo Rotors
-Stoptech Pads
-Goodridge Braided Brake lines
Now for the bad's it's a small list and nothing major but i want to be honest and upfront about the car
-Blown engine
-Missing the AC compressor
-No cat installed
-charcoal canister is missing
-some rust in the bottem of the frunk was cut out and a patch welded in but it is not the best repair
-There was a rust spot in the firewall where the drainage tunnel got stopped up, it was cut out and new metal installed. It's all welded up but needs metal finishing and paint to be perfect.
-Both lower quarters have some rust driver side is rusted out but comes with a twosrus patch panel. Passenger side only has surface rust
-The car has no radio
-There are 2 1" holes in the trunk wall that need rubber plugs
