t25torx
t25torx Reader
8/6/13 9:05 p.m.
Hmm. What engine/manual transmission combos could easily be dropped into this? http://tampa.craigslist.org/hil/cto/3959939466.html
moparman76_69
moparman76_69 Dork
8/6/13 9:10 p.m.
2.2/2.5 n/a or turbo, 2.2 TIII lotus head, 2.2 Maserati head, 2.0/2.4 n/a or turbo, 3.0 6G72, RWD V8 swap
turboswede
turboswede PowerDork
8/6/13 9:40 p.m.
A better question isn't what can be dropped, but where?
I vote for a twin turbo Mitsu V6 mounted in the trunk. Use a Mitsu truck block to get more displacement.
Gearheadotaku
Gearheadotaku UberDork
8/8/13 3:22 p.m.
looks like a good deal for a DD. Too bad it's an autotragic, but a swap can't be that hard....
t25torx
t25torx Reader
8/8/13 7:47 p.m.
Gearheadotaku wrote: looks like a good deal for a DD. Too bad it's an autotragic, but a swap can't be that hard....
Yeah if it wasn't an auto, I think it would be in my driveway already.
turboswede
8/8/13 7:58 p.m.
Autos aren't bad on those as they are really robust and great for drag racing and Autocross (left foot brake to get boost out of the corners, etc). My 87 Sundance Auto was a much better autoX car compared to my 87 shadow turbo with a stick. Same suspension and tires/wheels.
My Uncle autocrosses a CSX-T with a modified auto (5.30 final drive, manual valve body, quaiffe, etc) and is winning in DSP locally.
Besides manual swap just requires swapping the pedal rod, brake pedal, adding the clutch pedal and clutch cable bracket on the strut housing, the shifter, cables, transaxle, clutch/flywheel and drivelines. Luckily most of these parts are the same between the Daytonas and Lebarons, whether V6, 4, etc.
moparman76_69
moparman76_69 Dork
8/8/13 8:00 p.m.
yep change out the auto rod and brake pedal for the manual rod and clutch/brake pedals drill a hole for the cable and replace the auto shifter for the manual one.
ronholm
ronholm HalfDork
8/8/13 8:09 p.m.
I don't think you even have to drill a hole. Just pop out the plug.
Is that a 1990 though?
Rob_Mopar
Rob_Mopar SuperDork
8/8/13 10:06 p.m.
I'm 99% sure '90 is when they went to that interior. I bought an '88 Pacifica in November '90. Was considering a new TBI 2.5 ES with a 5-speed when the '88 was traded in.
'91's were out by then, so I'm a little foggy on the transition. I know '89 still had the earlier interior.
I still like the '80's dash better than the Star Trek Next Generation one.
x8uK7EC06gyCErEviCCZGSCK2EXoRRRXxnNK5vMNZX8aw7h6Lcsu6lrf2X7HJ7Ug
