3/26/13 Sorry, it's now off the market. At least, I'm sure I'll be sorry ;-)
Exciting times around here... between the Chumpcar team, new projects inbound and a new addition to the race team (daughter due in December ) I find I must thin the field of fun cars...
So, my Alfa 164 is up for sale! Asking $1750 with all parts/wheels etc. 198K miles. Located in dead center of PA.
My Readers Ride page for it : http://grassrootsmotorsports.com/reader-rides/2845/
The Bad:
Severe lack of clearcoat on most panels, extremely minor surface rust on the nose.
A single bubble of rust behind the right rear wheel.
Valve cover gaskets weep. Just hardening up with time and lack of driving.
Due for a timing belt. (50k or so since the last one)
One split in the rear seat upholstery (seam)
The Good:
Everything works. Every switch, all the windows, the seats, sunroof motor, power antenna, even the AC (though the fuse is pulled since it was never converted to R134 and the charge has faded). All the lights in the dash work (except the backlight for the exterior temp, just a bulb)
Brand new tires and correct battery. New plugs/wires/cap/rotor/voltage regulator/Saab idler pulley. New silicone intake runner couplers. Pair of spare matching wheels with snows. "S" cams installed, aftermarket chip, tweaked air meter. Poly bushings in the engine mount dogbone.
I'm sure I'm forgetting something, so ask away. Pictures below.
From Drop Box
From Drop Box
From Drop Box
Edit: Cross posted to AlfaBB
