IndyJoe
IndyJoe New Reader
12/10/15 11:28 a.m.
NMNA
$300 BMW 530i
Seller Says:
"mechanics special needs new tires and work on transmission car is drivable"
Adrian_Thompson
Adrian_Thompson UltimaDork
12/10/15 11:36 a.m.
The drivers seat looks seriously borked.
markwemple
markwemple Dork
12/10/15 11:44 a.m.
Usually that's a problem with the motors. 80s bmws have problems like that on a regular basis
NY535iManual
NY535iManual Reader
12/10/15 11:58 a.m.
Is it really a seat motor issue, or just an extreme case of cable stretch?
Robbie
Robbie SuperDork
12/10/15 12:04 p.m.
Its not either. The cable sheaths grow too long for the cable inside, and the end loses contact with the drive motor. It's called 'seat twist' on the bmw forums, and quite easy to fix (and free), i've done it myself.
First, move the seat (one motor generally works, one doesn't) to the straightest position you can. If neither motor works you can chuck the drive cable into a drill and move them that way. Pop the cable end out of the motor (it doesn't actually matter which end is having the problem, you can fix either end and it will fix the problem), use a bit of torch to heat the end, pull it off with pliers, cut sheathing off about 1/4 inch, re-heat and replace end fitting, put it all back together, fixed.
BYyjioykcyeDnjCAOmbq2PX3ElvFWzUrTYR15IVqubU88jlwaFtl0gUDp3Tm9LlN
