The_Jed
The_Jed UltraDork
11/13/14 7:47 a.m.
NMNA
https://peoria.craigslist.org/cto/4752116802.html
The_Jed
The_Jed UltraDork
11/13/14 7:55 a.m.
Don't tell the wife, but I kind of want it...
135 hp lol
Woody
Woody MegaDork
11/13/14 7:55 a.m.
That used to be the easy way to get rear disc brakes on your '65 Mustang.
The_Jed
The_Jed UltraDork
11/13/14 8:01 a.m.
I did not know that! A buddy of mine has a hopped up '68 with an ailing 8".
To the bat phone!!!
Klayfish
Klayfish UltraDork
11/13/14 8:01 a.m.
The Grenada never looked so good...or so bad.
Woody
Woody MegaDork
11/13/14 8:20 a.m.
The_Jed wrote: I did not know that! A buddy of mine has a hopped up '68 with an ailing 8". To the bat phone!!!
There are better options out there now. For a while, Versaille brake stuff was getting hard to come by. Not sure if that's still the case. But for $500, this still may be an easy route to take.
SilverFleet
SilverFleet UltraDork
11/13/14 9:20 a.m.
So I'm not the only one that immediately thought "Lincoln Versailles brake swap" when I read Lincoln Versailles.
The_Jed
The_Jed UltraDork
11/14/14 8:16 a.m.
He said he's going to go aftermarket, 35 splines, etc...
Still kinda want it. Tough to pass up a $500 car!
Woody
Woody MegaDork
11/14/14 8:31 a.m.
Especially one that already has four wheel discs and is already set up for a (better) V8.
Woody
Woody MegaDork
11/14/14 8:38 a.m.
When I was in high school, my best friend had a Granada ESS. It only had a six but had a three speed stick on the floor. It was reasonably fun back then.
bravenrace
bravenrace MegaDork
11/14/14 8:38 a.m.
IIRC, Versaille have a 9" rearend. If so, the disc brake setup wouldn't be a direct swap to a 8".
tedium850
tedium850 New Reader
11/14/14 9:02 a.m.
Another added bonus is the front spindles swap to give you front disk brakes (I think there are minor bump steer issues (bust I think they are correctable), but I know lots of people that did it). For the rear, the biggest challanges are the shock absorber mout/leaf spring plates (assuming you are swapping from an 8" or the 6 cylinder rear). I can't remember now, but seems like the Versalle has a staggered rear shock or more verticle (there is something different where the Versaille plates don't work as is) and the driveshaft yoke is different (easy enough to chang though). I have one in a 67 coupe that has been in there since the late 80's. Seems like I had a welder frind of mine cut and reweld the position of the shock mount on the plate. Keep in mind most of these rear ends were either, 2.47:1, 2.73:1, or 3.0:1 and very few were limited slip. Mine was the 2.47:1 which was awsome for cruising behind a toploader and 351W, but not so good for acceleration. The 3rd member is easy enouch to change out though.
All that being said, as I'm going through the car again I think I'm going to replace the brakes with something a little more modern (I think the Explorer or Crown Victoria brakes bolts up with minimal modifications and parts are much easier to find).
Sine_Qua_Non
Sine_Qua_Non HalfDork
11/14/14 9:25 a.m.
And it's gone
Woody
Woody MegaDork
11/14/14 11:29 a.m.
bravenrace wrote: IIRC, Versaille have a 9" rearend. If so, the disc brake setup wouldn't be a direct swap to a 8".
The whole rear axle is pretty much a drop in swap.
Woody
Woody MegaDork
11/14/14 11:31 a.m.
In reply to bravenrace:
http://www.mustangandfords.com/how-to/chassis-suspension/mump-0008-ford-granada-9-inch-rearend-swap/
The_Jed
The_Jed UltraDork
11/14/14 11:47 a.m.
Sine_Qua_Non wrote: And it's gone
Wasn't me!
Morbid
Morbid Reader
11/14/14 1:08 p.m.
Wasn't me!
Probably a good thing it wasn't you...
Woody
Woody MegaDork
11/14/14 1:10 p.m.
In reply to Morbid:
Was it you?
Morbid
Morbid Reader
11/14/14 1:17 p.m.
In reply to Woody:
Ummm, no. Definitely not
t4OvepvzQTT1eSp8GL4RRagBZmwFYqK7cP53vcIlRcAXm1NxzGd7Ojs9Tv91Q7xX
