EvanB
EvanB PowerDork
2/12/13 2:11 p.m.
http://cleveland.craigslist.org/cto/3582595034.html
bravenrace
bravenrace PowerDork
2/12/13 2:45 p.m.
If I needed another project....
DaveEstey
DaveEstey SuperDork
2/12/13 3:21 p.m.
Oh man, a Berton!
Knurled
Knurled UltraDork
2/12/13 4:39 p.m.
Helmet.
EvanB
EvanB PowerDork
2/12/13 4:55 p.m.
They do make a Miata look large.
turboswede
turboswede PowerDork
2/12/13 5:31 p.m.
Yet, oddly they have more storage space due to the dual trunks, plus they weigh nearly the same.
moparman76_69
moparman76_69 HalfDork
2/12/13 6:29 p.m.
Did they only paint these red?
Sil80redtop
Sil80redtop New Reader
2/12/13 6:38 p.m.
moparman76_69 wrote: Did they only paint these red?
One of my best friends had a yellow one, not sure if it was original paint, however.
Knurled
Knurled UltraDork
2/12/13 6:56 p.m.
EvanB wrote: They do make a Miata look large.
You met Jonathan? He's gainfully employed by a company that specializes in stuffing Honda K-series drivetrains into those.
Apparently, when you have a K20 in a 1600lb mid-engined car, it becomes quite the land missile.
EvanB
EvanB PowerDork
2/12/13 7:00 p.m.
Is that his? I just saw it in the parking lot of Harbor Freight in Mansfield, never met the owner.
Knurled
Knurled UltraDork
2/12/13 7:28 p.m.
No, he does not own one.
He does have some Foxes, XR4Tis, and some other Euro stuff. Apparently a 300hp Fox is also quite the land missile. Can't wait to see what 600hp is like.
128racecar
128racecar New Reader
2/12/13 7:32 p.m.
Body looks solid, but "needing engine repair" means not likely to sell soon. Cool cars, but not fun working on some aspects of these (once took me an entire weekend to replace the master cylinder).
moparman76_69
2/12/13 8:38 p.m.
Sil80redtop wrote: One of my best friends had a yellow one, not sure if it was original paint, however.
Datsun1500 wrote: Nope, I had a blue one. Lotsa brown ones out there as well
I only say that because there is the build thread on here with a red one (had a yellow engine compartment I saw one on CL cheap (really cheap) that was all torn apart that was red (oddly enough also with a yellow engine compartment), and this one is also red. The picture in this thread of the purplish one is the first non-red one I've seen.
phaze1todd
phaze1todd HalfDork
2/12/13 8:45 p.m.
That is one irresponsible X1/9 owner! Doesn't he know you're not supposed to get those things wet?!
DaveEstey
DaveEstey SuperDork
2/13/13 6:35 a.m.
I had a brown one. Great little car.
phaze1todd
phaze1todd HalfDork
2/13/13 6:46 a.m.
Metallic baby blue with off-white/black/tan Bertone. One of the first cars I learned to drive on from my dad's stable. Would not mind another if I could get it stripped down to bare metal and galvinized and dipped in a big vat of POR-15.
turboswede
2/13/13 1:43 p.m.
What sort of Engine work could it need? The 1500cc used in those were not interference engines and were EFI using a really simple Bosch system.
The cooling systems can be difficult to bleed all of the air out, so perhaps the headgasket puked. Luckily that isn't hard to solve either.
The 5-speed transmissions are known to be a little weak and reverse doesn't have a syncro so they tend to self destruct. Basically they all eventually start jumping out of gear when in reverse.
The hydraulics tend to fail due to sitting.
The 86 cars were the most comfy and best built versions, but were heavier than the early models.
http://www.xwebforums.com <--lots of info there.
EvanB
EvanB PowerDork
2/13/13 2:20 p.m.
I emailed to ask what kind of engine work it needed and they said it was sold. Actually the exact words were "we sold out".
racerdave600
racerdave600 Dork
2/13/13 2:58 p.m.
128racecar wrote: Body looks solid, but "needing engine repair" means not likely to sell soon. Cool cars, but not fun working on some aspects of these (once took me an entire weekend to replace the master cylinder).
I have had maybe a dozen or so "X's" (none red by the way) and the master cylinder is by far the hardest job on the entire car. I can't think of anything that comes close. 4 letter words are your best friend as you position yourself head first into the floorboard, wedged under the steering wheel. And then only to find you can't get the brake lines started. It's hard to describe what a joy this is.
turboswede
2/13/13 3:07 p.m.
Yeah, on the one I had I was going to use Tilton units mounted to the frunk firewall just to avoid that nonsense. Ended up scrapping the car instead, it was just too far gone to save. I still have the 1500 sitting on the floor along with a spare top, headlight pods, etc. If anyone is looking for parts, let me know before I buy another one myself.
Knurled
Knurled UltraDork
2/13/13 7:58 p.m.
phaze1todd wrote: That is one irresponsible X1/9 owner! Doesn't he know you're not supposed to get those things wet?!
Belongs in Say What?
wuuB2X4WL4ZzS4y65KUgwdoZ6ONx4c3c5scBFhfYj5hkYikGPsEcNqn8OUoM7zj2
