ae86andkp61
ae86andkp61 Reader
8/28/15 12:08 a.m.
My Corolla project is taking a different direction, so I am selling the very, very lightly used standalone engine management. This was state-of-the-art 12 years ago, and it is still more powerful and capable than many programmable options on the market today. I have the computer, manual, pinout, tuning software, 4-cylinder wiring harness, tach adapter, low-impedance injector driver, wideband oxygen sensor (controller is built into the ECU.) I want to find a new home for all of it and am asking $500 shipped in the Continental U.S. The computer, wiring harness, tach adapter, oxygen sensor, and injector driver have maybe a couple hours of use from new.
The good:
-Capable of handling just about every upgrade you might make down the road; more cylinders, more sensors, more triggers, more boost, more nitrous, etc.
-Huge tables and an amazing closed-loop learning mode for self-tuning based on target AFR.
-Robust and well-sealed. Can do more than anything else you will get for the same price.
The challenges:
-FJO sold the design to Holley, who sell it as the Dominator EFI, so support is rather limited.
-The user interface takes a bit to get used to, and takes some poking around and experimenting to make the most of the features available.
-I struggled to get it to work well with Alpha-N and my ITBs. For speed-density tuning (with or without boost) it works a treat!
Why am I selling?
-oldeskewltoy and I bought two of these units together. His works really well on his car with a modified redtop 4AGE plenum and a large single throttle. I got tired of seeing him driving around the neighborhood with a E36 M3-eating grin on his face while I struggled with tuning. I am also way to prideful and stubborn regarding removing my individual throttles, hence the FJO sale. His car is awesome with the same computer, emissions compliant, daily-driveable, and goes really well for a 1.6 more than 30-years-old!
OST sweet 341B Corolla
What is needed to complete this setup?
You would need to source sensors, ignition coils or COP, a trigger wheel, and a few connectors. Wiring may need some modification, but it all has labels. My harness was built for a four cylinder with four injectors (EV1 connectors inclued) two GM coils for waste spark, GM MAP, Toyota tach and TPS (connector included) GM AIT, oil press, fuel pres., coolant temp, oil temp, with Hall effect cam and crank angle sensors, plus external relays running the fuel pump and cooling fan (although ECU could control them if desired.) At the moment the harness has the tach adapter and injector driver wired in, populated plugs for the ECU side, fairly long leads (all labeled) with some connetors for sensors, ring terminals for grounds, as well as a USB port for the laptop. The harness isn't complete, but it is one hell of a start, especially for a four cylinder car. If you would like more specifics on the wiring, let me know.
ae86andkp61
ae86andkp61 HalfDork
8/30/15 11:39 a.m.
Oh yeah, forgot to mention that you can use 16x16 tables or expand to 32x32 for more resolution if you desire.
ae86andkp61
9/4/15 12:56 p.m.
Open to offers on this, and I can throw in the FJO dual coils with ignition module.
ae86andkp61
10/22/15 2:49 p.m.
Still available, still open to offers.
thewelder
thewelder New Reader
10/24/15 7:45 p.m.
How hard would it be to get this running on a bike engine. Never worked with a stand alone before
ae86andkp61
10/24/15 11:15 p.m.
It would do a great job of running a bike engine, but packaging might a bit tricky. All of the advanced capabilities mean it is more like a hard bound book and not so much a deck of cards. Roughly 10" by 6" by 2" or so. What kind of bike?
thewelder
10/25/15 11:01 a.m.
Gsxr 1000 in a car. Room isn't a problem. Trying to get away from the power commander
ae86andkp61
10/26/15 12:33 a.m.
Not super-familiar with the Power Commander. The FJO really seems to shine in boosted applications. For normally-aspirated applications, I found it needs a not-too-spikey manifold pressure signal, so it isn't great on my induction system:
It does work great with this similar engine, different intake:
What is your induction like? Are you running a MAP sensor?
ae86andkp61
10/29/15 8:50 p.m.
To give you guys a better idea of the completeness of the wiring:
ae86andkp61
11/7/15 3:13 p.m.
1 Ground with ring terminal installed
2 Ground with ring terminal installed
3 Tach adapter-just bolt it down
4 Ground with ring terminal installed
5 Ground with ring terminal installed
6 Connector for ignition coils needs to be spliced-4 wires
7 +12v constant-single wire
8 Tach signal from igniter-single wire
9 +12V switched fuel pump relay-single wire
10 +12V switched fuel injectors-single wire
11 Electric cooling fan-single wire
12 +12v constant with ring terminal installed
13 Crank angle sensor-3 wires
14 Oil temp sensor-2 wires
15 Oil pressure sensor-3 wires
16 Cam angle sensor-3 wires
17 Engine Coolant temperature sensor-2 wires
18 MAP Sensor connector needs to be spliced-3 wires
19 Fuel Pressure sensor-3 wires
20 Air intake temperature sensor-2 wires
21 +12v switched power-1 wire
22 Unassigned triggers (2 of them) wired up, can be used for switching
23 Ground with ring terminal installed
24 Two extra control outputs-currently unassigned, but wired up and ready to go
25 USB port-plug your laptop in here
26 Optional AFR gauge with wiring
27 TPS currently wired with Toyota plug
28 Oxygen sensor-ready to go
29 Optional Oxygen sensor extension wiring with connectors-ready to go
WksoI3xvNrZAP0YfVrOjtPb093cWlegcbicotOixwUGsztXyC4g0L8KVzu86lTkh
