JohnyHachi6
JohnyHachi6 Dork
9/22/13 9:53 p.m.
This one is mine, some association
Trying to get some cash/space/time together for a new project and I've decided it's probably time to let this one go.
Short version: needs work, lots of potential, $1000. Here's the long version for those who are interested:
It's an 80's-tastic 1987 Merkur XR4Ti. Turbo, fuel-injected 2.3L Lima engine, 5-speed trans, independent suspension all-around. Designed by Ford Europe and hand assembled in Germany! Luxury and power in an economical and stylish package! Ok, seriously, it's a piece of crap. But, it could be a ton of fun for the right person.
HISTORY: I bought this car as a joint venture along with a couple other friends and GRMers a few years ago. We had grand aspirations of running this in LeMons, but it never happened. We spent a lot of time taking care of a lot of issues and it's much better than when we got it, but still needs more TLC, or someone who knows 80's era Fords.
When we got the car it had a blown head gasket so we removed the manifolds, turbo and head. Everything was still straight and the bearings were good, so we put on a new head gasket set and put it back together. Ran into a ton of wiring issues after that, so we replaced the engine wiring harness with a good used one (was in excellent condition, but still 25 years old).
We got the car started up but the turbo and exhaust manifold flanges were warped and leaking massive amounts of exhaust gas. We fulled the turbo and manifold again and trued up the flange faces with a flycutter on a mill. They're good now. Everything was put back on again. Got all the plumbing and wiring hooked up to find out that the fuel pumps had died from sitting for so long. Replaced the high-pressure pump and finally got it started again a couple weeks ago.
CURRENT CONDITION: Car is hard to start, but I've driven it around the lot where it's stored for 20-30 minutes on a couple occasions recently. The car is down on power and doesn't want to rev past ~3k rpm. No smoke or knock/detonation. The fuel system needs more work and there are probably some more vacuum leaks to fix. But, at this point I think the right person could get this car running well without too much pain. Possible oil leak - maybe rear main seal. Bad T/O bearing (works, but makes lots of noise when clutch is out). Don't think the alternator is charging. Have a spare but it doesn't seem to work either Brakes kinda work, but I wouldn't trust them on the street - need to be bled at least, but don't drag and they do stop the car at least at low speed.
Interior is rough but I think we've got all the parts for it and most of them are still in the right spots. Needs headliner and seats recovered. Most of the gauges don't work (not hooked up). Has some Sierra RS parts. Power windows both work great. Sunroof works great and doesn't leak (hand-crank).
Exterior is OK. Looks decent from 20' but the black paint is peeling in places (was red previously). Body is pretty darn good with only one or two small dents and zero rust that I can find. Underbody and wheel-wells all look fantastic. Has the great Ford BBS knock-off wheels (have all the center-caps). Driver's exterior door handle needs attention, but works. Rear hatch release needs work (doesn't latch - common issue I hear). Rear spoiler is badly cracked (have spare). I have all the parts for the front-end (bumper, bumper support, fog/turning lights, front fascia, etc). All in good shape.
SPARES:
- Hood
- Extra front fascia panel
- Bi-plane rear spoiler
- New brake rotors
- New brake pads
- Distributors (2x)
- Alternator
- Fuel injectors (2x?)
- Gaskets (oil pan, exhaust, misc intake/tb, etc)
- Intake manifold
- New oil filter
- Coolant/washer reservoirs (IIRC)
- Newer Ford MAF
Tons of other parts I can't remember.
NEW PARTS INSTALLED:
- Head gasket kit
- Head bolts
- Timing belt (W.P. too? can't remember)
- Acc. belts
- Intake gaskets
- Exhaust gaskets (manifold and turbo flange)
- Valve cover gasket
- Thermostat housing
- Thermostat
- Oil filter
- Oil feed line (turbo)
- Oil return gasket (turbo)
- Oil pressure sender
- Fuel pump
- Spark plugs
- Dist. cap and rotor
- Battery terminal
- Rad. cap
- Misc coolant hoses
Sure I'm forgetting other things.
MAJOR WORK NEEDED:
- Fuel system work (low-pres. pump, filter, maybe injectors cleaned?)
- Vac. leak check
- Cooling fan wiring
- Front body work re-installed
- Brakes bled (at minimum)
- Leak on coolant reservoir fixed
- Oil leak addressed?
- Work on gauges
- Tires?
Ok. So, that's most of the story on this car. I really love the thing and think it's quirky in a really cool way, but I don't have the time to keep working on it. Like I said, I've had it running and driving at low speed recently, but it's real hard to start and down on power. Definitely needs to be trailered. Located in Atlanta, GA.
I'm asking $1000 (GRM Price) which is quite a bit less what we have into it. You should be able to part it out for more than that if you wanted to. Have a clean GA title. Would also consider making a deal for seat time with someone who want to turn it into a crapcan racer or already is running a team.
I also have a nice spare set of Borbet 5-spoke wheels (80's era) that fit the car and would consider throwing those in for the right price.
Car has 4 years of dirt sitting on it. Would be happy to wash it up and take more pics if anyone is interested. Didn't have time today.
Link to Full Album
Celica also available for the right price/buyer - more on that later, or PM me if really interested.
JohnyHachi6
JohnyHachi6 Dork
9/22/13 9:58 p.m.
Oh, almost forgot - has a full tank of gas!
Probably should be flushed though.
paranoid_android74
paranoid_android74 HalfDork
9/23/13 8:02 a.m.
Man I want one of these, I've always thought they were cool.
GLWS!
hobiercr
hobiercr HalfDork
9/23/13 9:05 a.m.
Argh, I did not need to see this. ATL is in striking distance for a weekend run and this would satiate two ADD wants. Any chance to throw in one of the Hobie 16's in the deal?
BTW, l I need a storage yard like that. SWMBO would be MUCH happier if all my crap was somewhere else.
JohnyHachi6
JohnyHachi6 Dork
9/23/13 11:16 a.m.
In reply to paranoid_android74:
Thanks!
In reply to hobiercr:
I might be able to help with transport. Either trailer it part way, or bring it down over a weekend vacation. If you're serious let me know and we can talk details.
yamaha
yamaha PowerDork
9/23/13 11:23 a.m.
Thank you for being in Atlanta.....
Ian F
Ian F UltimaDork
9/23/13 12:34 p.m.
yamaha wrote: Thank you for being in Atlanta.....
+1.
Granted, I just want the T-9 transmission... I'd probably part out the rest.
hobiercr
hobiercr HalfDork
9/23/13 1:28 p.m.
JohnyHachi6 wrote: In reply to paranoid_android74: Thanks! In reply to hobiercr: I might be able to help with transport. Either trailer it part way, or bring it down over a weekend vacation. If you're serious let me know and we can talk details.
Hmm, are you coming to the GRM Challenge? That is about halfway. Also, any interest in something like this...?
Currently sitting lower on cut springs but with brand new struts all the way around. We ate a motor at Sebring and I have another motor sitting ready to install right now. The car would be running and driving before being delivered. Chump legal cage, seat and current belts. Only thing needing changed would be the location of the kill switch. I would be looking to get closer to $2500 for this as it comes with a ton of spares and is essentially race ready.
hobiercr
hobiercr HalfDork
9/23/13 1:40 p.m.
Oh yeah, it also comes with 6 Dunlop Direzza tires, 2 brand new and 4 barely used (~20 laps). spare doors (with glass), rear glass, 1 extra disassembled motor, 1 blown motor (block shot but head (fresh) is probably good. spare rack, calipers/hubs/rotors plus more I'm sure I'm forgetting. BTW it is a '94 WITH title and street legal.
JohnyHachi6
JohnyHachi6 Dork
9/23/13 1:43 p.m.
Man... That's very tempting, but I need to keep working on thinning the herd, so I'll have to turn down trades.
Don't think I'll be making it to the challenge this year.
jsymonds
jsymonds New Reader
9/24/13 9:20 a.m.
I was one of the other guys working on this fine piece of automotive craftsmanship. You should buy it!
Sil80redtop
Sil80redtop Reader
9/24/13 10:05 a.m.
I wish I could park that next to my XR so I could figure out how to put it back together. :)
dansxr2
dansxr2 Dork
9/24/13 9:26 p.m.
I really want an XR4Ti!!! Wish you were closer
Brett_Murphy
Brett_Murphy UltraDork
9/24/13 9:26 p.m.
If this had been for sale when I had my pile, I would have bought it.
JohnyHachi6
JohnyHachi6 Dork
9/24/13 10:43 p.m.
In reply to dansxr2:
Might be able to work out delivery up your way. Let me know if you're interested.
JohnyHachi6
JohnyHachi6 Dork
9/25/13 9:16 p.m.
Bump. Need to get this moved out in the next week or so.
Any takers for major parts (engine, trans, etc)? If I can't get a buyer for the whole thing lined up, I'll probably have to scrap the body soon. Would hate to do it, but can't keep the thing around much longer.
JohnyHachi6
JohnyHachi6 Dork
10/7/13 5:31 p.m.
Anyone else interested? Can get $400 at the local scrap yard, but would like to see this go to someone who would get it going again.
BlueInGreen44
BlueInGreen44 New Reader
10/7/13 7:10 p.m.
Oh man... I would love an XR4 project and I know a guy in Atlanta who could help get it here. I would even consider giving up the current 924 project for the space. But... dunno if the money is there at the moment.
JohnyHachi6
JohnyHachi6 Dork
10/7/13 11:46 p.m.
Shoot me an offer if you're interested - definitely willing to negotiate. I'd just like to pass it on to the next lucky individual at this point.
JohnyHachi6
JohnyHachi6 Dork
10/9/13 7:37 p.m.
$800 negotiable. Help fund my future challenge and crapcan racing adventures!
Uaqxs0bwSeEZmBri2hnMo3AaUNQy7MtzeSICVksiRwNod6KGpmdJvrfYntJBOlD3
