GPDren
GPDren New Reader
7/6/10 5:09 p.m.
I bought this for a project that never got going. Time to make some room.
The turbo is an oil and water cooled Mitsubishi TE04H with an internal wastegate.
Here's the good and the bad: There is a small crack in the turbine side near the center section. The exhaust elbow is included but one of the bolts is broken off. There is a bunch of radial shaft play and a little axial play, definetely needs a rebuild. The fins look like they kissed the wall of the compressor but appear to be okay. They aren't bent or broken. There is a 90 degree hardpipe for the oil drain and a couple inch brass pipe with an elbow for the water included.
Okay, so that was mostly just bad, but the turbo does look like a good core for rebuilding. I'm asking $30 OBO and will ship at buyers expense. I'm located in Columbus, GA about 90 miles south of Atlanta and I'll meet within a reasonable distance (or unreasonable if you live somewhere interesting and are paying for gas!!)
GPDren
GPDren New Reader
7/8/10 7:11 a.m.
$25 OBO, I want this gone.
Vigo HalfDork
7/13/10 10:34 p.m.
FYI that's a stock piece for 89-92 or so turbo 2.5L fwd chryslers. In working condition itll move enough air to make 200-220 hp in perfect conditions.
I hope someone takes it and it doesnt end up scrap, but i have to say good luck getting money for it. Bump
GPDren
GPDren New Reader
7/16/10 5:34 p.m.
Thanks for the info Vigo!
I'd give it to someone who'd use it before letting it go for scrap. Not that giving it away is my first choice.
$15 OBO! The wastegate actuator is worth almost that!
Spinout007
Spinout007 Dork
7/16/10 11:12 p.m.
Hmm are you close to I 75?
GPDren
GPDren New Reader
7/17/10 10:39 p.m.
I'm just under two hours west of I-75. Pretty much a straight shot west from Warner Robins.
1niQPxI3Hf9bF7eHVphi8fCaeu6Vqy3QKdyvwkWoXKhuM2KBI2xzG9LSfOvIdRZM
