I need two sets of the front lower control arm brackets. That's #38 and 39 in this pic. PM with requirements, please!
Thanks, JThw8. petegosset, I don't know for sure if the Europa piece is the same. I think the bolt is shorter, and I need them long enough to go through a Spitfire frame. I'll get some measurements for you.
Curmudgeon wrote: Thanks, JThw8. petegosset, I don't know for sure if the Europa piece is the same. I think the bolt is shorter, and I need them long enough to go through a Spitfire frame. I'll get some measurements for you.
Heard from buddy, he thinks he has a set, needs a week or 2 to get to his storage and check. Just update here if you find a set before then.
Still no local joy at this point 11/24. JThw8, there's a 'front' (offset hole) and 'rear' (centered hole) bracket, I need 2 of each if he's got them.
I could also use a steering U joint assembly if he has that, if he has two spares that would be even better.
Thanks!
Hey Curm,
I just saw this. I have the whole suspension/running gear from my $2013 Challenge car. PM me. Thanks T
