DukeOfUndersteer
DukeOfUndersteer UltimaDork
12/15/16 8:26 a.m.
NMNA
Seller said: Please read this ad fully and look at the photos. Gallery: https://www.flickr.com/photos/90990240@N08/sets/72157671770817966 This is not a ready-to-drive car. This is for an enthusiast in search of a project. This is a 1987 Nissan Pulsar with the rare SportBak rear hatch. I bought this car at auction because I didn't want to see it go to the scrapyard, but I have way too many projects. Here is what I know about the car: The odometer reads 296,000 miles, however it is not currently functioning so this was the reading when it stopped working, actual mileage is higher. The car is complete, minus a couple of trim pieces. The interior is deteriorating in the way that 80's Nissans do, however it is all there. The seats are in decent shape, the dash pad is not. The exterior is a little on the rough side, previous owner put a yellow fender on the front. Other places have some surface rust and/or primer. I haven't found any heavy rust damage to the structure. Suspension is rough. Tires are dry-rotted, but currently hold air. Here is what I have learned about the car: 1. It starts, runs, drives and stops. No joke, it fires up on the first try and idles... I cranked it accidentally while messing with the ignition and it just fired up. Not perfectly, but it runs. I have driven it around in the pasture and on the road by the house & even down to the gas station a few miles away. 2. The pop-up headlights work. 3. The air conditioning functions: it doesn't blow cold air, but when the dash switch is on, the compressor cycles. 4. The T-tops work and come off and go on fine. The side windows work fine. Here is what I have done to the car: -Oil & filter change -Basic tune-up (plugs, wires, cap, rotor) I also replaced the missing pre-heater tube on the air cleaner -Fixed the cable release for the fuel door (wasn't broken, just popped out) -Cleaned and vacuumed the inside. Stain on drivers floor is hydraulic oil from a jack someone left in the car. -Replaced two broken reverse light lenses with two junkyard pieces. All the other lenses are in good shape. -Re-cut and replaced the vinyl decals on the back glass. The SportBak hatch: The hatch is rare. If you're a Nissan fan, you probably already know; but these were not wildly popular in the states. This ine is in decent shape with a few dings to the fiberglass here and there, nothing a little work won't fix. All of the glass is perfect. The gas struts need replacing. Personally I like it. The car will not come with any keys; the one key I received promptly snapped in half the first time I tried to use it. The ignition switch will turn with a medium screwdriver. Cash only. Clear blue title. So that's the deal. Email me. Scammers: Don't waste your time. -I do not need help selling the car. -I will not accept any payment other than cash for the car. -I will not ship the car.
http://dallas.craigslist.org/dal/cto/5906511993.html
classicJackets
classicJackets HalfDork
12/15/16 8:48 a.m.
That Sportbak alone is probably worth close to $800. Based on the wheels, though, I doubt this has the CA16, which is supposed to be a fantastic engine (derivative of the famous CA18), but hard to find parts for.
golfduke
golfduke HalfDork
12/15/16 8:51 a.m.
man... It's so ugly that I want it insanely bad.
Klayfish
Klayfish UberDork
12/15/16 9:13 a.m.
That is fantastic '80's goodness. Love the SportBak and love those tail lights.
Adrian_Thompson
Adrian_Thompson MegaDork
12/15/16 9:23 a.m.
I haven't seen on in over a decade and I've never seen one with the back open like this pic.
Cooter
Cooter Reader
12/15/16 9:37 a.m.
In reply to Adrian_Thompson:
Well, to be fair, that 2x4 probably was Special Order.
Cooter
Cooter Reader
12/15/16 9:50 a.m.
classicJackets wrote: That Sportbak alone is probably worth close to $800. Based on the wheels, though, I doubt this has the CA16, which is supposed to be a fantastic engine (derivative of the famous CA18), but hard to find parts for.
They pop up for cheaper than you'd think.
Mister Fister
Mister Fister Reader
12/15/16 10:12 a.m.
what in the actual fuck?
spitfirebill
spitfirebill UltimaDork
12/15/16 10:18 a.m.
In reply to Mister Fister:
Are you trying to get E36 M3 canned?
petegossett
petegossett UltimaDork
12/15/16 10:26 a.m.
I remember when these were new, it seemed like a spacecraft had landed from another dimension...
SilverFleet
SilverFleet UberDork
12/15/16 11:03 a.m.
I love these. This one looks a bit rough around the edges, bit if it were nearby, I'd probably own it by now.
Cooter
Cooter Reader
12/15/16 11:21 a.m.
In reply to SilverFleet:
I'm trying my best not to check to see if Megabus still goes to Dallas from Chicago.
Dbussey1
Dbussey1 Reader
12/15/16 11:45 a.m.
FYI that ad has been up for well over a month - i bet you could negotiate a little.
Wall-e
Wall-e MegaDork
12/16/16 5:53 p.m.
Cooter wrote: In reply to SilverFleet: I'm trying my best not to check to see if Megabus still goes to Dallas from Chicago.
Twice a day of that helps.
q6hyUYx8qeSH2pWpqJzp86NF1rsTGvWXrrIKtMisJI3Xst2Jt6rbHQerbaCA0L4A
