EvanB
MegaDork
10/16/18 8:14 p.m.
Mine, totally affiliated. $1400 obo
I bought this around a year and a half ago and haven't really done much with it. I got it running but didn't drive it much. I bought it from the original owner with 95k miles. I replaced the timing belt and a few other things.
96k miles, 5 speed manual, clear title.
Current issues:
Turn signals do not work. I bypassed the hazard switch and they worked once, I have not done any further diagnosis.
The coolant tank leaks from the lower hose, the plastic is cracked.
It currently has no brakes. They worked well, then were soft. I tried to bleed them and now they don't work at all. I can not see any leaks. I either did a terrible job bleeding them or the master is berkeleyed.
Paint is faded.
Positives:
It isn't very rusty.
It is all stock.
Here are some pictures from when I bought it. It looks pretty much the same. I will take current pictures tomorrow.
Located in Columbus, Ohio
Good luck. If I literally just didn't buy a car *today* as a father/son project, I'd be all over it.
Patrick
MegaDork
10/16/18 9:00 p.m.
Do you accept bits of string?
Patrick
MegaDork
10/17/18 7:48 a.m.
Crap. For some reason i’vE always wanted one of these
If somebody buys this as a drivetrain donor I'll buy the front and rear subframes and suspension pieces.
JmfnB
MegaDork
10/17/18 1:37 p.m.
If someone buys this as a drivetrain donor and sells the suspensions to ¯\_(ツ)_/¯ you can disassemble it in my garage and leave the title... I just want the shell
*Le sigh*
I was hoping you would sell this when I had extra money laying around.
EvanB
MegaDork
10/17/18 4:41 p.m.
The underside is good for an Ohio car. There is some rust starting in the usual spot where the rocker and floor meet. It does not look bad yet but I have not removed the plastic rocker cover. There is some damage to the fender and plastic cladding just behind the driver side front wheel.
I apparently didn't do a good enough job with the pressure washer since there is some mud left.
My buddy had an '86. It had a poorly implemented HX35Y turbo and stock brakes. That car is the closest I've ever come to dying in a vehicle. I still want one.
These seem to be drying up which is a real shame. There is so much '80s Euro engineering in them. They are exotic enough that they are special but use common Ford parts. If I ever become successful again, I'd by a well sorted one in a heartbeat.
Is that an extended, extended Dodge? Cool.
85 4 door cab+93 extended cab=super cab
