BTD
BTD Reader
7/31/18 5:03 p.m.
Hey GRM,
I picked this up a little over two months ago with plans to turn it into an HPDE car. It had been modded by the previous owner and was run in SCCA autocross competition for the better part of the last decade, usually in BSP. The car ran great when I test drove it, and ran great on the drive home. It even still runs great when the battery is charged. Seriously, it's fast and badass.
It's major fault (that I didn't realize at the time) was that the charging system isn't working right. For some reason the battery will just run itself down and the car will eventually stop responding to throttle inputs due to the low voltage. Then it will stop running entirely until you can hook it back up to a trickle charger and let everything come back. Then it's a badass again.
The body is in OK shape, though it has a number of scuffs, bruises, and other imperfections. I'd rate it as a 5/10, but I'm picky. The biggest scuffs are on the driver-rear (PO says he backed into a pole), on the driver-front bumper (no idea) and on the driver-front fender (my father in law scraped the fender with his car). Not perfect, but looks nice from ~10 ft. Would clean up well with some bribes to the 2018 challenge judges.
I've just purchased a new house, my MR2 decided to eat it's differential bearings, and a few other personal expenses have come up, so the RX7 really has to go. I don't have time to take it on, so I'm letting it go for what I have into it, which isn't much.
Here is my initial thread on the car: https://grassrootsmotorsports.com/forum/grm/soi-just-bought-an-rx-7-turbo-ii-school-me/139473/page1/
Mods list:
Suspension -
Koni Sport shocks w/ Ground Control coilover conversion perches
Eibach springs, needle roller bearings
Ground Control Camber plates
AWR rear camber adjustment links
Seam welded rear subframe
ARP extended wheel studs
Stainless steel brake lines, Hawk HPS pads
Newer front wheel bearings
Torsen S5 RX7 rear differential (factory diff included)
Engine -
AFCO Aluminum radiator
Ducted SPAL electric fan
S5 RX7 Alternator
Walbro fuel pump
720cc secondary injectors
Corksport stainless steel exhaust - currently has two cats in it, comes with a test pipe
Corksport Aluminum Intake Pipe
RTek 2.1 ECU control w/ working palm pilot  (I haven't been able to get it to recognize the ECU, but it's obviously tuned)
PLX Wideband O2 sensor
Aftermarket Boost Gauge
Odyssey PC680 Battery
I've taken it to a local Mazda shop for diagnosis of the charging system, which they attribute to a bad wiper control computer (?) - basically there's a relay somewhere in the system that has gone bad and isn't allowing things to charge. I'm no electrical expert, so I'll defer that problem to whatever challenge team takes this on. I may be able to replace this part ebfore the next owner purchases it, but I can't guarantee it will fix the charging issue.
As it sits, the car doesn't run because of it. That said, I'm being honest when I say it runs really well when charged. It's the perfect challenge car for a team with some electrical know how.
The car passed emissions with no problem when I had it running, and will come with an unused Colorado emissions slip. Carfax is clean as well and can be provided to potential buyers. Comes with a stack (2"+ thick) of receipts and service records from the previous owner.
Give me SOLD and it's yours. That leaves $18 to buy yourself dinner on the way home.
Open to trades, particularly for a reliable car that I could daily drive if needed. Located in Fort Collins, CO.
I want this to go to a GRM-er. Seriously. I want to see this in GRM next year after the $2018 challenge. It would do extremely well even in its current state, and is some tires and a tune away from being an absolute monster.
BTD
BTD Reader
7/31/18 5:05 p.m.
More photos:
mrhappy
mrhappy HalfDork
7/31/18 6:21 p.m.
i wish I had the money and time to get this! Looks like a great car!
Greg Voth
Greg Voth Dork
7/31/18 6:21 p.m.
Damn.  I wish you were closer.
Brett_Murphy
Brett_Murphy PowerDork
7/31/18 7:16 p.m.
That's pretty rust free. I'm glad you're far away, as I've sworn off FC RX-7s, but that car at that price would be hard to refuse.
Clutch type LSD for the win!
rdcyclist
rdcyclist New Reader
7/31/18 8:05 p.m.
With the change of format to the Challenge this year, this is enticing.
Sent you a PM...
docwyte
docwyte SuperDork
8/1/18 8:25 a.m.
I almost bought this when it was on RMSCCA.  You're not helping me!  What's that red button and on/off switch for?  Ejecto seato Cuz?
BTD
BTD Reader
8/1/18 10:57 a.m.
That turned the datalogger on/off and the button started/stopped the log. It has since been removed.
Robbie
Robbie PowerDork
8/1/18 11:22 a.m.
I'm coming to Denver to visit my parents at Thanksgiving. I will buy it from you then if you still have it (but I know that you won't).
Awesome car.
dean1484
dean1484 MegaDork
8/3/18 9:21 p.m.
Your charging issue I think is that the bulb in the dash is burnt out. It has been a while since I had my FC so I am a bit foggy on the details but I know it is a known thing and easly repaired
BTD
BTD Reader
8/4/18 12:41 p.m.
SOLD
Javelin
Javelin MegaDork
8/4/18 4:07 p.m.
BTD said:
SOLD
I don't know whether to be happy or cry. Congratulations(?)
5SpZjmaI7B00FrDnE1RuhumYYUJoM3EN5kpsWbIrAW767KDbKoMaYV29oaB9Wmtw
