petegossett
petegossett UltimaDork
11/11/16 1:01 p.m.
KyAllroad
KyAllroad UberDork
11/11/16 3:16 p.m.
Weren't those era 200sx's really heavy? Any real performance potential?
petegossett
11/11/16 3:51 p.m.
In reply to KyAllroad:
No idea, but a RWD/5-speed car that seems to be in decent shape for $1200 would be fun for rallyx, if it actually existed around here...
JamesMcD
JamesMcD Dork
11/11/16 5:46 p.m.
I've always liked those. Looks good to me!
DeadSkunk
DeadSkunk UberDork
11/11/16 6:10 p.m.
Just over 100 HP and almost 2600 lb. Figure out how to double the horsepower and you would have some fun. Or, find 600 lb to remove.
mndsm
mndsm MegaDork
11/11/16 6:18 p.m.
Those are fun. Though every single one I've ever seen had doriftbro camber even in Stock form. The rear suspension was a mess and wore out fast.
Trackmouse
Trackmouse Dork
11/12/16 11:12 a.m.
Let's be real here. That's a Nissan. It has parts interchangeability out the wazoo! Ca18det pumps out 175hp stock, turn up the boost and you've got your 200hp. The rear suspension is not a mess, it's a hodgepodge. Came with IRS and SRA. 240sx parts fit with little modifications.
Knurled
Knurled MegaDork
11/12/16 2:49 p.m.
Those were fun to drive because the horrible rear suspension geometry meant the rear suspension sucked up into the wheelwells if you so much as nudged the throttle. If the shocks were at all worn, you could bounce the back end up and down like you had hydraulics.
I would imagine that this made them incredibly annoying to drive "fast" unless you stiffened up the suspension at both ends until it didn't move.
spitfirebill
spitfirebill UltimaDork
11/12/16 3:37 p.m.
Didn't they also come with the VG?
Knurled
Knurled MegaDork
11/12/16 3:41 p.m.
In reply to spitfirebill:
Every S12 that I've seen was VG engined. I guess some of them had CA18E engines too. That might mean a CA18DET could be a drop in, but I don't trust Nissan to not change a bunch of hardpoints anymore.
VG30_S12
VG30_S12 Reader
11/14/16 3:43 a.m.
Ok that is a ca20e powered s12, only vg powered ones were the 86 and up to 88 se models For the most part, must 240 stuff will fit with little modification,ka sr vg r20/25/26 pretty much anything under the moon
the rear suspension is z31 300zx yeah it's got issues but they can be banged out. If sra even better, but those were only early 84 models(which this could be) Front can be swapped to s13/14 stuff There is literally tons of possibility and potential with this platform... if I had the cash id go buy if it ran well
Hit me up if you want any info on s12s as I've had quite a few, or hit up www.club-s12.org for support too
Woody
Woody MegaDork
11/14/16 6:13 a.m.
Didn't they have a turbo option on the higher end hatchbacks?
spitfirebill
11/14/16 7:31 a.m.
Woody wrote: Didn't they have a turbo option on the higher end hatchbacks?
Sure did. One of my co-workers drove one.
spitfirebill
11/14/16 1:05 p.m.
If this was closer, I would consider making it my DD.
4QCnR4MQPyhBHDKFiRvveDTa5d0n4FLEPCG7jfVNr0HyMKaw4A4eb7Z3YJEA6dcE
