RossD
RossD MegaDork
4/19/18 12:25 p.m.
noddaz
noddaz SuperDork
4/19/18 12:47 p.m.
Hmmm.  That is different.
4/19/18 1:12 p.m.
Heavy for that engine?
dculberson
dculberson UltimaDork
4/19/18 1:14 p.m.
I can think of a whole lot of engines I would rather swap into a Corvair in 2018. Maybe if this was 1998 that would be a compelling swap.
nutherjrfan
nutherjrfan SuperDork
4/19/18 11:05 p.m.
"non-returnable"
nutherjrfan
4/19/18 11:06 p.m.
nutherjrfan
4/19/18 11:07 p.m.
spitfirebill
spitfirebill MegaDork
4/20/18 7:36 a.m.
Who would go through all that just to leave the powerglide in there?
volvoclearinghouse
volvoclearinghouse UberDork
4/20/18 8:31 a.m.
THIS.
grover
grover Reader
4/20/18 12:57 p.m.
that thing probably has all of 45hp to the wheels
Antihero
Antihero HalfDork
4/20/18 1:01 p.m.
Seems like a solution to problem that no one should be foolish enough to have.
On the plus side it apparently comes with a dufflebag full of wiring for you to sort thru and contemplate how your life has gone so wrong that you now have a honda powered corvair
Cooter
Cooter HalfDork
4/20/18 1:55 p.m.
Plot twist:
His Thunderbird convertible has a Corvair engine swapped into it.
Robbie
Robbie PowerDork
4/20/18 2:21 p.m.
There's a mighty car mods joke in here somewhere
oldopelguy
oldopelguy UltraDork
4/20/18 2:24 p.m.
The corvair probably weighs about the same as the Accord,  so performance would be Honda-ish.  Adding a radiator and some ducting out front and the Honda engine most likely weighing less than the corvair one would probably help the handling and balance of the car. But doing all that and keeping the powerglide? Wow.
grover
grover Reader
4/20/18 6:09 p.m.
I didn't believe you so I looked it up...yep, the accord is 100lbs heavier.  color me suprised.
Nitroracer
Nitroracer UltraDork
4/20/18 10:00 p.m.
I've seen a B20-Turbo powered car on a Corvair forum.  That combination seemed worth the effort.
Mr. Lee
Mr. Lee UberDork
4/21/18 4:16 a.m.
I'm thinking screaming turbo honda motor with 2 gears. Might be amusing.
cUqD4Yuwty0Hxj7aNY9FWfwoNxpLCmz87SgQn8lQTixt8bpsYUjfl8NfxmQf0TVj
