Well, I’m changing my mind again. I raced a Miata last weekend and loved driving something new, so I'm going to rent some more rides for now. Or buy a Miata at somepoint.
Year:1983 Make: Volkswagen Model: Rabbit GTI Class: SCCA H Production / HSR HPC Logbook? Yes current SCCA logbook w/2016 annual. Location:Road Atlanta area.
Specs: Body in good shape, no major damage. Body is vinyl wrapped. NO ENGINE 5 speed manual gearbox w/welded differential (currently removed but included) Koni shocks front/Bilstein rear Adjustable coilover sleeves. Custom rear trailing arm. Race rear sway bar. Spherical front bushings. Front strut tower bar. Camber plates up front. Aftermarket air dam with brake ducts. Racing radiator. 8 gallon ATL Fuel Cell, all replaced within last 12 months including foam, bladder, and case. Four wheel disc brakes, rear converted from 16V Scirocco. Wilwood brake bias knob. Custom dash with RPM, Oil temp, AFR wideband, volts, and water temp. Electric fan for hot days on the grid. Fiberglass hood. All plastic windows. MK2 front hubs. New wheel bearings. Racing header w/exhaust. Innovate Lambda sensor/gauge. MSD coil. New air filter. New alternator. Adjustable fuel pressure regulator. Suede Sparco steering wheel. New ATE master cylinder. New ECS brake lines front and rear. Tech-53 lower steering column bearing. Tech-53 lower steering column repair.
This car is sold as a roller. Included is the rolling chassis with all suspension components, fuel cell, everything you need except for the engine, seat, harness, window net, tires, and transponder, and a few odds and ends. Will be sold on wheels I bought to push the car on. I do have some used takeoffs laying around you're welcome to take.
Finished third at Road Atlanta Majors Sunday race back in March, 1st in HP at the 2015 ARRC, class wins at The Mitty 2015. Runs 1:47s at Road Atlanta, easily more time in it with some setup work. Regional winner and obviously able to podium on the Majors level.
[B]PRICE: $2,000.00 [/B]
CURRENT PHOTOS: more at www.tibbettforsale.weebly.com
