petegossett
petegossett UltimaDork
7/18/16 7:51 a.m.
NordicSaab
NordicSaab HalfDork
7/18/16 7:54 a.m.
That look like all kinds of fun. I wonder what it would take to put a plate on it... Oh wait, im in FL; it can be titled as is.
bluej
bluej UltraDork
7/18/16 7:55 a.m.
Is that an old drive shaft he's collected the exhaust primaries into?
Interesting..
mndsm
mndsm MegaDork
7/18/16 8:28 a.m.
NordicSaab wrote: That look like all kinds of fun. I wonder what it would take to put a plate on it... Oh wait, im in FL; it can be titled as is.
Looks good enough for mn too.
petegossett
7/18/16 8:51 a.m.
I'm still trying to figure out the suspension - is that a VW front axle turned around backwards?
nocones
nocones UltraDork
7/18/16 9:46 a.m.
Large lateral arms with trailing links appears to be the design on the front suspension. The lower looks to be some FWD stock type part. That could either be a lot of good parts for the money or a pile of frustration. Seems worth a look it could make a decent enough autox car for someone.
petegossett
7/18/16 2:14 p.m.
Against my better judgement, I contacted the seller. He bought it as a project & does't know much about it, and said the same of the person he bought it from. He did say it's chain-drive to a sprocket, but has separate CV shafts. It has 4-wheel disc brakes, but they all need rebuilt/replaced. The current engine on it is a "1200" (but no further details) and isn't locked up, though it is missing wiring. The other engine is a '96 Vulcan 800 that runs good, but the carb floods when it sits.
I might take a look at it this week, if it hasn't sold, and report back. It doesn't look very comfortable to sleep in, so not much chance of me dragging it home though.
singleslammer
singleslammer UberDork
7/18/16 2:18 p.m.
The 1200 might be a bandit engine maybe. Looks like a riot until a weld breaks
Stefan (Not Bruce)
Stefan (Not Bruce) MegaDork
7/18/16 3:44 p.m.
singleslammer wrote: The 1200 might be a bandit engine maybe. Looks like a riot until a weld breaks
shocks mounted in single sheer are always a good idea....
irish44j
irish44j UltimaDork
7/18/16 3:53 p.m.
I especially like the exhaust header that the driver can lean his head back against and/or burn all his hair off with.
petegossett
7/18/16 6:21 p.m.
irish44j wrote: I especially like the exhaust header that the driver can lean his head back against and/or burn all his hair off with.
Yeah, there are a whole lot of Really Bad Ideas going on currently, but I blew up the pics and the tig welds look professionally done - the frame looks like it could even be aluminum.
There's a tag on the hoop support that reads "Dyna"...does that sound familiar to anyone?
underpowered
underpowered New Reader
7/18/16 8:04 p.m.
petegossett wrote: There's a tag on the hoop support that reads "Dyna"...does that sound familiar to anyone?
Just a sticker for a manufacturer of motorcycle ignition systems.
petegossett
7/18/16 9:23 p.m.
In reply to underpowered:
Ah, good to know. Thanks!
Grtechguy
Grtechguy MegaDork
7/19/16 7:53 a.m.
In reply to singleslammer:
From the pictures, looks like an earlier GS engine. Maybe an 1100 at best.
slowride
slowride HalfDork
7/19/16 5:06 p.m.
jeez, hope you don't have long hair!
escort1991
escort1991 Reader
7/19/16 10:23 p.m.
Grtechguy wrote: In reply to singleslammer: From the pictures, looks like an earlier GS engine. Maybe an 1100 at best.
By the engine covers, '80 or '81ish GS1100?
I think it could be titled in WI under the Hobbyist plate.
penultimeta
penultimeta Reader
7/23/16 3:23 p.m.
That whole thing is very Mad Max. Do want.
Knurled
Knurled MegaDork
7/25/16 12:35 p.m.
I mounted a set of shocks to the front of an RX-7 in single shear because the struts were blown badly, just drilled a hole in the control arm and welded a piece of angle iron to the strut tower. Never an issue. It did start to crack the strut tower, so I welded some stuff over in the engine bay side for strength.
wvumtnbkr
wvumtnbkr SuperDork
7/25/16 12:39 p.m.
That is how the bottom of the struts are mounted on the rear of an FC RX7.
Stefan (Not Bruce)
7/25/16 12:47 p.m.
Just because it CAN work, doesn't mean it should be done that way.
but, whatever.
lastsnare
lastsnare Reader
7/25/16 12:50 p.m.
it reminds me of this that showed up at our last autocross, I know absolutely nothing about it, but appears equally safe xD
petegossett
7/25/16 5:55 p.m.
In reply to lastsnare:
Serious question - does the driver have legs?
RCOfAlsB16tx94gzANeg23zkNk5QIp3H6le3grUqfljBr0jddmF6tFYg7CpA0oA7
